Introdução
Replacement of the front bumper may seem daunting at first. However, this guide will show you a step-by-step process to replace the front bumper. The front bumper is located at the front part of the car under the hood, the hood is in front of the windshield. Replacing your front bumper may be necessary since it may be damaged or cracked. Damaged front bumpers may have trouble holding the headlights.
While replacing the front bumper, you need to be aware of the hazards of making sure the vehicle is parked properly and not putting your whole body under the car. You will be using a socket wrench with a 10mm socket. Now you are ready to replace the bumper.
O que você precisa
The front bumper is located under the hood and below the headlights. The red box (photo 3) is the bumper.
There is a lever in the grill of the car. Press up to activate it
After activating the hood you will be able to hold the hood up with one arm.
In the red circle from the second picture, there is a thing holding the metal stick called a hood lift. Pull the hood lift and press it up.
The hood lift will have a hook to enter and attach it self to the hood. Put the hook of the hood lift inside the hole. (Example of this in the third picture).
In the front bumper, there is a light panel to fully remove the bumper you will need to detach the cables of these lights.
In this photo (second slide), we remove the right (passenger) light.
Press on the clips on the sides of the cable (where my thumb and index finger resides). Then pull to slide the cable.
This cable is still on the right side of the bumper. There are four sections for this cable we need to match to remove.
In the third photo, there are gaps in the socket where the light enters. We simply need to match it with the gaps and we can remove the light.
The second photo showcases (the material in the red circle) the part we need to match.
Now the operation we need to do is to twist the light while pulling carefully to see if the gaps match with the material.
