Introdução
If you are experiencing poor braking performance or a noise when braking, then it may be time to replace the rear brakes.
Follow this video tutorial by YouTuber NutzAboutBolts to complete the replacement yourself.
O que você precisa
Instruções em vídeo
Quase terminado!
Conclusão
Um comentário
Good video but you also want to take the metal slides that brake pads slide on and clean them with a wire brush. Then put some of your brake caliper grease on the areas that the pads slide on. It's also a good idea to grease up the face of the piston and the ears on the front side of the caliper. You wanna grease any spots that contact another part that moves or slides.
Michael White - Responder
