Ir para o conteúdo principal
1992-1999 BMW 3 Series Brake Light Bulb Replacement
O que você precisa
  1. 1992-1999 BMW 3 Series  Brake Light Bulb Replacement, Brake Light Bulb: passo 1, imagem 1 %32 1992-1999 BMW 3 Series  Brake Light Bulb Replacement, Brake Light Bulb: passo 1, imagem 2 %32
    • Determine which brake light is out. Have a friend step on the brake and see which light does not illuminate.
    • In the trunk, locate the plastic cover that protects the taillight. Turn the handle clockwise (as shown by the arrow above the handle) and gently pull outwards.
  2. 1992-1999 BMW 3 Series  Brake Light Bulb Replacement: passo 2, imagem 1 %32 1992-1999 BMW 3 Series  Brake Light Bulb Replacement: passo 2, imagem 2 %32
    • Pinch the top and bottom of the power connection. Pull hard on the power connection to remove it, disconnecting the wiring.
  3. 1992-1999 BMW 3 Series  Brake Light Bulb Replacement: passo 3, imagem 1 %32 1992-1999 BMW 3 Series  Brake Light Bulb Replacement: passo 3, imagem 2 %32
    • Undo all four nuts with the 8mm socket and ratchet.
    • The nuts are marked by red circles in the second image.
  4. 1992-1999 BMW 3 Series  Brake Light Bulb Replacement: passo 4, imagem 1 %32 1992-1999 BMW 3 Series  Brake Light Bulb Replacement: passo 4, imagem 2 %32 1992-1999 BMW 3 Series  Brake Light Bulb Replacement: passo 4, imagem 3 %32
    • To remove the taillight from the metal frame, push outwards (towards the back of the car) on the back of one of the plastic bulb carriers.
    • Support the taillight housing with your free hand to keep it from falling and being damaged.
  5. 1992-1999 BMW 3 Series  Brake Light Bulb Replacement: passo 5, imagem 1 %32 1992-1999 BMW 3 Series  Brake Light Bulb Replacement: passo 5, imagem 2 %32 1992-1999 BMW 3 Series  Brake Light Bulb Replacement: passo 5, imagem 3 %32
    • The brake light bulb is behind the bottom right plug. Push the plug inwards while turning it counterclockwise to remove the assembly.
    • You may need to use a lot of force to turn the plug.
  6. 1992-1999 BMW 3 Series  Brake Light Bulb Replacement: passo 6, imagem 1 %32 1992-1999 BMW 3 Series  Brake Light Bulb Replacement: passo 6, imagem 2 %32
    • The 7528 bulb is in the off-white plastic carrier. Apply slight pressure downwards and twist counterclockwise to remove the bulb.
  7. 1992-1999 BMW 3 Series  Brake Light Bulb Replacement: passo 7, imagem 1 %32
    • To determine whether or not a bulb is burnt, check for a connection break in the bulb. In the image shown, wires run continuously between both connections. This means the bulb is working correctly and can be installed.
    • Insert the new bulb into the white housing and turn clockwise to install.
  8. 1992-1999 BMW 3 Series  Brake Light Bulb Replacement: passo 8, imagem 1 %32 1992-1999 BMW 3 Series  Brake Light Bulb Replacement: passo 8, imagem 2 %32
    • The plastic carriers only fit into the taillight carrier one way. The fit is very snug against the metal ground.
    • Align the two plastic tabs with the indents in the metal sheet. Push hard inward while twisting clockwise until the bulb is horizontal, similar to the other four bulbs. When the bulb fits correctly, you will hear a loud snap.
    • The bulb carrier is very hard to place correctly. Ensure the tabs are lined up, and apply hard pressure while turning clockwise. If the bulb carrier does not sit properly, remove it and reseat it.
Conclusão
7 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 10-4, Green Fall 2015 Membro de Cal Poly, Team 10-4, Green Fall 2015
CPSU-GREEN-F15S10G4
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 47
Últimos 30 dias: 237
Duração total: 27,225
