Ir para o conteúdo principal
1991-1996 Toyota Camry Oil and Oil Filter Replacement
O que você precisa
Vídeo de Apresentação
  1. 1991-1996 Toyota Camry Oil and Oil Filter Replacement, Oil and Oil Filter: passo 1, imagem 1 %32
    • Locate the oil filter under the exhaust manifold in the front of the vehicle
    • source.
  2. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: passo 2, imagem 1 %32
    • Place the Lisle 63600 Oil Filter Tool over the filter, use an extension on the ratchet to reach around the hot manifold, and loosen the filter
    • source
    • Be careful not to burn yourself on the hot manifold.
  3. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: passo 3, imagem 1 %32
    • Unscrew the oil filter and let it drain into the oil drain pan
    • source
    • Make sure the pan is aligned to catch oil from both the filter and drain plug.
  4. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: passo 4, imagem 1 %32
    • Carefully remove the old oil filter
    • source.
  5. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: passo 5, imagem 1 %32 1991-1996 Toyota Camry Oil and Oil Filter Replacement: passo 5, imagem 2 %32 1991-1996 Toyota Camry Oil and Oil Filter Replacement: passo 5, imagem 3 %32
    • Clean the mating surface where the new filter will be installed
    • Ensure there are no old seals or debris that could affect the new filter's seal
    • source.
  6. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: passo 6, imagem 1 %32
    • Install the new oil filter by hand tightening it
    • source.
  7. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: passo 7, imagem 1 %32 1991-1996 Toyota Camry Oil and Oil Filter Replacement: passo 7, imagem 2 %32
    • Move to the oil drain plug location and remove it using the 14mm socket and ratchet
    • source
    • Let the oil drain into the pan
    • source.
  8. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: passo 8, imagem 1 %32
    • Replace the old gasket on the drain plug with a new one, if necessary
    • source.
  9. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: passo 9, imagem 1 %32 1991-1996 Toyota Camry Oil and Oil Filter Replacement: passo 9, imagem 2 %32
    • Tighten the drain plug using the 14mm socket
    • source
    • Clean up any excess oil
    • source.
  10. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: passo 10, imagem 1 %32 1991-1996 Toyota Camry Oil and Oil Filter Replacement: passo 10, imagem 2 %32 1991-1996 Toyota Camry Oil and Oil Filter Replacement: passo 10, imagem 3 %32
    • Refill the engine with 5W-30 oil using a funnel
    • source
    • This engine should take about five quarts
    • source
    • Be careful when filling the oil, as there is a plate just under the fill opening that can cause spills
    • source
    • Tilt the funnel to ensure the oil goes into the engine
    • source.
Conclusão
Uma outra pessoa concluiu este guia.
eCuration
Membro desde: 05/19/17
376.693 Reputação
Autoria de 234 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.817 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 34
Duração total: 9,796
