Ir para o conteúdo principal
1990-1993 Honda Accord EX Engine Air Filter Replacement
O que você precisa
  1. 1990-1993 Honda Accord EX Engine Air Filter Replacement, Engine Air Filter: passo 1, imagem 1 %32 1990-1993 Honda Accord EX Engine Air Filter Replacement, Engine Air Filter: passo 1, imagem 2 %32 1990-1993 Honda Accord EX Engine Air Filter Replacement, Engine Air Filter: passo 1, imagem 3 %32
    • Flip the switch underneath the steering wheel to open the hood.
  2. 1990-1993 Honda Accord EX Engine Air Filter Replacement: passo 2, imagem 1 %32 1990-1993 Honda Accord EX Engine Air Filter Replacement: passo 2, imagem 2 %32 1990-1993 Honda Accord EX Engine Air Filter Replacement: passo 2, imagem 3 %32
    • Open the hood, and keep it in place using the prop rod.
  3. 1990-1993 Honda Accord EX Engine Air Filter Replacement: passo 3, imagem 1 %32 1990-1993 Honda Accord EX Engine Air Filter Replacement: passo 3, imagem 2 %32
    • Remove the four 1.3 cm Phillips screws from the cover of the case.
  4. 1990-1993 Honda Accord EX Engine Air Filter Replacement: passo 4, imagem 1 %32 1990-1993 Honda Accord EX Engine Air Filter Replacement: passo 4, imagem 2 %32
    • Remove the cover of the casing.
  5. 1990-1993 Honda Accord EX Engine Air Filter Replacement: passo 5, imagem 1 %32 1990-1993 Honda Accord EX Engine Air Filter Replacement: passo 5, imagem 2 %32 1990-1993 Honda Accord EX Engine Air Filter Replacement: passo 5, imagem 3 %32
    • Remove the old air filter and replace it with a brand-new one.
    • Place the new air filter in the same position as the old one otherwise, you will not be able to screw the cover back on.
  6. 1990-1993 Honda Accord EX Engine Air Filter Replacement: passo 6, imagem 1 %32 1990-1993 Honda Accord EX Engine Air Filter Replacement: passo 6, imagem 2 %32
    • Place the cover back on the casing and screw it back in place.
    • Do not tighten the screws too hard or you risk the chance of breaking the screws.
Conclusão
Oscar Sanchez
Membro desde: 10/24/23
133 Reputação
Autoria de 1 guia
Equipe
CSU Los Angeles, Team 8-9, Ribeiro Fall 2023 Membro de CSU Los Angeles, Team 8-9, Ribeiro Fall 2023
CSULA-RIBEIRO-F23S8G9
Membros da 3
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 20
Duração total: 92
