Ir para o conteúdo principal
1986-1993 Volvo 240 Tie Rods Replacement
O que você precisa
  1. 1986-1993 Volvo 240 Tie Rods Replacement, Front Wheels: passo 1, imagem 1 %32 1986-1993 Volvo 240 Tie Rods Replacement, Front Wheels: passo 1, imagem 2 %32 1986-1993 Volvo 240 Tie Rods Replacement, Front Wheels: passo 1, imagem 3 %32
    • Jack up the front of the car and place it on jack stands.
    • Never work on or underneath a car that is only supported by a jack. The jack may slip or fail, resulting in serious injury or even death.
    • Use an impact wrench or lug wrench to remove the five 19 mm lug nuts from the front wheel.
    • The wheel lug nuts should be torqued to 85 ft-lbs when the wheels are put back on the car.
    • Pull the front wheel off the wheel lugs and set it aside.
  2. 1986-1993 Volvo 240 Tie Rods Replacement, Tie Rods: passo 2, imagem 1 %32
    • Use an impact wrench to remove the 19 mm tie rod end nut near the brake rotor.
    First obstacle - nut in the circle is spinning with bolt from tie rod. How to get it off?
    Siim Soiver - Responder
  3. 1986-1993 Volvo 240 Tie Rods Replacement: passo 3, imagem 1 %32
    • Use a pair of pliers to remove the zip tie or clamp securing the inner tie rod boot.
  4. 1986-1993 Volvo 240 Tie Rods Replacement: passo 4, imagem 1 %32 1986-1993 Volvo 240 Tie Rods Replacement: passo 4, imagem 2 %32 1986-1993 Volvo 240 Tie Rods Replacement: passo 4, imagem 3 %32
    • Unscrew the inner tie rod from the steering rack. It may be necessary to use a large pair of groove joint pliers to loosen it.
    • Remove the tie rod assembly once it is free from the steering rack.
  5. 1986-1993 Volvo 240 Tie Rods Replacement: passo 5, imagem 1 %32
    • Before installing the new tie rod assembly, you must adjust it to the correct length. Keep one tie rod assembly together while assembling the other one.
    • The outer tie rod simply screws onto the inner rod and can be removed by unscrewing it.
    • Screw the outer tie rod onto the inner tie rod.
    • Adjust the length of the tie rod assembly by spinning the outer tie rod so that it is the same length as the existing assembly. Once it is the correct length, use the back-in nut to secure the outer tie rod in place.
    • Repeat this process for the other tie rod assembly, using the new assembly as your guideline for the proper length.
  6. 1986-1993 Volvo 240 Tie Rods Replacement: passo 6, imagem 1 %32
    • Install the inner tie rod end into the steering rack and tighten it with groove joint pliers.
  7. 1986-1993 Volvo 240 Tie Rods Replacement: passo 7, imagem 1 %32 1986-1993 Volvo 240 Tie Rods Replacement: passo 7, imagem 2 %32
    • Pull the inner tie rod boot completely over the inner tie rod and onto the steering rack.
    • Secure the boot in place with whatever hardware came with your new tie rods.
    • If your new tie rods did not include hardware for the boot, a zip tie will work just fine.
  8. 1986-1993 Volvo 240 Tie Rods Replacement: passo 8, imagem 1 %32 1986-1993 Volvo 240 Tie Rods Replacement: passo 8, imagem 2 %32 1986-1993 Volvo 240 Tie Rods Replacement: passo 8, imagem 3 %32
    • Place the tie rod end through its hole next to the brake rotor.
    • Install the tie rod end nut and tighten it to 44 ft-lbs with a torque wrench or impact gun.
    Please i want the original part number of tie rod end volvo 240
    hamada_gggg - Responder
Conclusão
With the new tie rods installed, place the wheels back on the car and lower it to the ground.
3 outras pessoas executaram este guia.
David Hodson
Membro desde: 04/13/10
150.476 Reputação
Autoria de 127 guias
4 comentários
Recommend buying new boots. Even though my boots where not cracked it would have made the job easier. Great step by step.
Diane Slaughter - Responder
Thanks for the brilliant tutorial! Could you please add the estimated time to do the job? Thanks
pablo - Responder
Adapted what I saw to fix an older Toyota Camry. Unemployed so could not afford a mechanic, this tutorial saved me money and stress. Thank-you
Kym - Responder
how risky is it to break the seals when unscrewing the inner tie rod end ?
plattard.e - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 19
Duração total: 11,123
