Introdução
This guide will walk you through the procedure to change the oil in your Volvo 240 equipped with the B230F red block 2.3 liter engine.
It is typically recommended that you change your vehicle's oil every 3,000 miles for extreme running conditions. However, this number can vary depending on your operating conditions, age of your vehicle, number of miles on your engine and your driving habits. Use of synthetic oils can help reduce engine wear and are advisable for older engines or if your typical driving involves extended periods of stop and go traffic.
O que você precisa
Raise the front of the car with a jack and support it on jack stands.
Place a drain pan directly underneath the red oil pan.
Use a 1" box end or socket wrench to loosen the drain plug on the bottom of the oil pan.
Once the drain plug is completely loose it will fall out and oil will begin to drain out of the oil pan.
While you are waiting for the oil to drain, check the gasket on the drain plug and replace it if necessary.
Once the draining oil slows to drip, wipe off the area around the drain plug with a shop towel or rag.
Locate the oil filter on the side of the engine.
Position the drain pan so that it is underneath the oil filter.
Turn the oil filter counterclockwise to loosen it. If the filter is on too tightly, you may have to use an oil filter wrench to loosen it.
Drain the old oil from the filter into the drain pan.
Remove the oil filler cap from the top of the engine by turning it counterclockwise and lifting it up.
Place a funnel inside the filler hole and pour four quarts of 10W-30 oil into the engine.
Reinstall the oil filler cap.
Start the engine and let it run, checking the drain plug and oil filter for any leaks.
Remember to check your engine's oil level periodically to make sure that you do not have too much or too little.
8 outras pessoas executaram este guia.
