Ir para o conteúdo principal
1986-1993 Volvo 240 Front Brake Caliper Replacement
O que você precisa
  1. 1986-1993 Volvo 240 Front Brake Caliper Replacement, Front Wheels: passo 1, imagem 1 %32 1986-1993 Volvo 240 Front Brake Caliper Replacement, Front Wheels: passo 1, imagem 2 %32 1986-1993 Volvo 240 Front Brake Caliper Replacement, Front Wheels: passo 1, imagem 3 %32
    • Jack up the front of the car and place it on jack stands.
    • Never work on or underneath a car that is only supported by a jack. The jack may slip or fail, resulting in serious injury or even death.
    • Use an impact wrench or lug wrench to remove the five 19 mm lug nuts from the front wheel.
    • The wheel lug nuts should be torqued to 85 ft-lbs when the wheels are put back on the car.
    • Pull the front wheel off the wheel lugs and set it aside.
  2. 1986-1993 Volvo 240 Front Brake Caliper Replacement, Front Brake Calipers: passo 2, imagem 1 %32 1986-1993 Volvo 240 Front Brake Caliper Replacement, Front Brake Calipers: passo 2, imagem 2 %32
    • Use a 15 mm box end wrench to remove the two bolts on the back of the brake caliper.
  3. 1986-1993 Volvo 240 Front Brake Caliper Replacement: passo 3, imagem 1 %32 1986-1993 Volvo 240 Front Brake Caliper Replacement: passo 3, imagem 2 %32
    • Lift the brake caliper off the rotor and set it aside.
    • Place the caliper on some type of support so that you do not put too much strain on the brake hose.
  4. 1986-1993 Volvo 240 Front Brake Caliper Replacement, Front Brake Caliper: passo 4, imagem 1 %32 1986-1993 Volvo 240 Front Brake Caliper Replacement, Front Brake Caliper: passo 4, imagem 2 %32
    • Use an open-end wrench to loosen the 11 mm fitting where the brake hose attaches to the caliper.
    • Brake fluid will come out of the loosened brake hose. You should keep a bucket or pan nearby to collect it.
    • Be careful when handling brake fluid, as it may strip paint and dissolve some plastics.
    • Detach the brake hose and remove the brake caliper.
    • When you install the new calipers you will need to bleed the brakes to remove any air from the brake fluid lines.
Conclusão
Uma outra pessoa concluiu este guia.
David Hodson
Membro desde: 04/13/10
156.050 Reputação
Autoria de 127 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 28
Últimos 30 dias: 89
Ao todo: 6,804
