Ir para o conteúdo principal
1986-1993 Volvo 240 Engine Air Filter Replacement
O que você precisa
  1. 1986-1993 Volvo 240 Engine Air Filter Replacement, Engine Air Filter: passo 1, imagem 1 %32
    • The engine air filter housing is located at the front of the engine bay, between the engine and the radiator.
    • Open the lid of the filter housing by releasing the metal clips along the edge of the lid.
  2. 1986-1993 Volvo 240 Engine Air Filter Replacement: passo 2, imagem 1 %32 1986-1993 Volvo 240 Engine Air Filter Replacement: passo 2, imagem 2 %32
    • Once the clips are released, pull the lid away from the air filter housing.
    • Grab the air filter and remove it from the filter housing.
    • Be sure to install the new air filter in the same orientation as the old one.
Conclusão
David Hodson
Membro desde: 04/13/10
150.500 Reputação
Autoria de 127 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 20
Duração total: 8,216
