Ir para o conteúdo principal
1986-1993 Volvo 240 Clutch Replacement
O que você precisa
  1. 1986-1993 Volvo 240 Clutch Replacement, Manual Transmission: passo 1, imagem 1 %32 1986-1993 Volvo 240 Clutch Replacement, Manual Transmission: passo 1, imagem 2 %32
    • Lift the bottom of the shift boot to expose the shifting socket.
    • Use snap ring pliers to remove the circlip securing the shifter to its socket.
  2. 1986-1993 Volvo 240 Clutch Replacement: passo 2, imagem 1 %32 1986-1993 Volvo 240 Clutch Replacement: passo 2, imagem 2 %32
    • Remove the set screw securing the shifter yoke pin. This assembly can be located on the underside of the car, above the transmission and directly below the shift lever.
    • Grab the head of the shifter yoke pin with your hands or pliers and pull it out.
    • If the pin won't readily come free, try jiggling the shifter while you pull the pin.
  3. 1986-1993 Volvo 240 Clutch Replacement: passo 3, imagem 1 %32 1986-1993 Volvo 240 Clutch Replacement: passo 3, imagem 2 %32
    • Remove the shift lever by pulling it straight up.
    • Remove the plastic bushing in the bottom of the shifter socket.
  4. 1986-1993 Volvo 240 Clutch Replacement: passo 4, imagem 1 %32
    • Remove the 6 nuts and bolts securing the drive shaft to the guibo and the back side of the transmission.
    • Only four nuts and bolts are visible and marked in the first picture. The others are hidden on the other side of the drive shaft.
    • Take note of how the bolts, washers and guibo are positioned. They are required to go back in the same way.
  5. 1986-1993 Volvo 240 Clutch Replacement: passo 5, imagem 1 %32 1986-1993 Volvo 240 Clutch Replacement: passo 5, imagem 2 %32 1986-1993 Volvo 240 Clutch Replacement: passo 5, imagem 3 %32
    • Support the drive shaft with a jack, jack stand, or other prop so it does not fall and get damaged or injure someone when the support is removed.
    • Remove the 4 bolts securing the drive shaft support.
    • Do not lose the washers on the 4 bolts or the spring and washer on the opposite side of the support.
    • Slowly lower the drive shaft and separate it from the transmission.
    • Remove the guibo and metal separator plate.
    • The separator may not come out with drive line and will be in the transmission.
  6. 1986-1993 Volvo 240 Clutch Replacement: passo 6, imagem 1 %32 1986-1993 Volvo 240 Clutch Replacement: passo 6, imagem 2 %32 1986-1993 Volvo 240 Clutch Replacement: passo 6, imagem 3 %32
    • Remove the bolts securing the transmission to the engine and to the starter.
    • Support the transmission so it doesn't fall when the final support is removed.
    • Generally, a jack is recommended for this.
    • Remove the four bolts securing the transmission support to the chassis.
    • Lower the transmission out of the car.
    • In many instances, the transmission may not come free from the engine once the bolts are removed. If this is the case, a pry bar is recommended to help separate the two.
  7. 1986-1993 Volvo 240 Clutch Replacement, Clutch: passo 7, imagem 1 %32 1986-1993 Volvo 240 Clutch Replacement, Clutch: passo 7, imagem 2 %32
    • Remove the 6 allen bolts securing the pressure plate to the flywheel.
    • Remove the pressure plate.
  8. 1986-1993 Volvo 240 Clutch Replacement: passo 8, imagem 1 %32
    • Remove the clutch by pulling it straight away from the flywheel.
    • When reinstalling, use a centering tool like the one shown here.
Conclusão
Uma outra pessoa concluiu este guia.
Phillip Takahashi
Membro desde: 08/22/11
86.248 Reputação
Autoria de 87 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 47
Duração total: 2,338
