Ir para o conteúdo principal
1986-1993 Volvo 240 Brake Master Cylinder Replacement
O que você precisa
  1. 1986-1993 Volvo 240 Brake Master Cylinder Replacement, Brake Master Cylinder: passo 1, imagem 1 %32
    • The brake master cylinder is located directly underneath the brake fluid reservoir near the driver side of the engine bay.
  2. 1986-1993 Volvo 240 Brake Master Cylinder Replacement: passo 2, imagem 1 %32 1986-1993 Volvo 240 Brake Master Cylinder Replacement: passo 2, imagem 2 %32 1986-1993 Volvo 240 Brake Master Cylinder Replacement: passo 2, imagem 3 %32
    • Twist the brake fluid reservoir cap counterclockwise and remove it.
    • Remove as much brake fluid from the reservoir as possible by sticking a clean rag inside the reservoir.
    • When you remove the rag, be sure not to place it on any painted or plastic surfaces. Brake fluid will strip paint and deteriorate plastic.
  3. 1986-1993 Volvo 240 Brake Master Cylinder Replacement: passo 3, imagem 1 %32 1986-1993 Volvo 240 Brake Master Cylinder Replacement: passo 3, imagem 2 %32
    • If your brake fluid reservoir has a fluid level sensor, disconnect it by pressing down on the plastic tab and pulling the connector straight out of its socket.
  4. 1986-1993 Volvo 240 Brake Master Cylinder Replacement: passo 4, imagem 1 %32
    • Use a 10 mm open end wrench to disconnect the two brake lines from the master cylinder.
    • There were still be fluid in the master cylinder that will drip out of the connections; this is normal. Use a clean rag to clean up any dripping fluid.
  5. 1986-1993 Volvo 240 Brake Master Cylinder Replacement: passo 5, imagem 1 %32 1986-1993 Volvo 240 Brake Master Cylinder Replacement: passo 5, imagem 2 %32
    • Use an open end or socket wrench to remove the 17 mm nuts on either side of the master cylinder that attach it to the brake booster.
    • Remove the brake master cylinder, taking care not to damage or bend the brake lines.
Conclusão
Don't forget to flush & bleed with new brake fluid! (separate how-to required)
5 outras pessoas executaram este guia.
David Hodson
Membro desde: 04/13/10
150.467 Reputação
Autoria de 127 guias
3 comentários
Thanks this was great. Additional instructions are required about how to disconnect the reservoir from the master cylinder. I've broken so many plastic bits on my Volvo that I was scared to really put much force into getting the reservoir off. I kept thinking "There must be a trick..." but no there's no trick you just have to pull really hard while doing your best to not damage the reservoir. Could have saved me some time as I stared at it wondering what the "trick" could be.
There's also a plug on one side of the old master cylinder that you will need to take out and put on your new one.
Thanks again for posting these instrux.
Brant Louck - Responder
Thanks very much David Hopson & very helpful.
M. T Lam - Responder
David! Can you help!? Just got a 1991 Volvo 240 and the brakes went, just as you described. You mention that it is common with the 240? Can you elaborate?
Tracy Murphy - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 22
Duração total: 9,008
