Ir para o conteúdo principal
1985-1988 Volvo 740 Tire Rotation
O que você precisa
  1. 1985-1988 Volvo 740 Tire Rotation, 1985-1988 Volvo 740 Jacking Front Wheels: passo 1, imagem 1 %32
    • Turn car off and remove keys from ignition.
    • Place car in park (automatic) or neutral (manual).
    • Engage parking brake.
  2. 1985-1988 Volvo 740 Tire Rotation: passo 2, imagem 1 %32
    • Use hydraulic jack on frame of car to raise car.
    • Place jack head underneath frame of car.
    • Only necessary to jack the car until the wheels are just off the ground.
  3. 1985-1988 Volvo 740 Tire Rotation: passo 3, imagem 1 %32
    • Place jack stand on frame of car and remove jack.
    • Do no work under car supported only by hydraulic jack, serious injury or death may occur.
  4. 1985-1988 Volvo 740 Tire Rotation, 1985-1988 Volvo 740 Jacking Rear Wheels: passo 4, imagem 1 %32
  5. 1985-1988 Volvo 740 Tire Rotation: passo 5, imagem 1 %32 1985-1988 Volvo 740 Tire Rotation: passo 5, imagem 2 %32
    • Place jack head underneath frame couple (pictured).
  6. 1985-1988 Volvo 740 Tire Rotation: passo 6, imagem 1 %32 1985-1988 Volvo 740 Tire Rotation: passo 6, imagem 2 %32
    • Do not work under car supported only by hydraulic jack, serious injury or death may result.
  7. 1985-1988 Volvo 740 Tire Rotation, 1985-1988 Volvo 740 Tire Rotation: passo 7, imagem 1 %32 1985-1988 Volvo 740 Tire Rotation, 1985-1988 Volvo 740 Tire Rotation: passo 7, imagem 2 %32
    • Pry off the all four hub caps by placing a small flathead screwdriver between hubcap and rim pulling the screwdriver away from tire.
    • Pull hubcaps away from tires.
  8. 1985-1988 Volvo 740 Tire Rotation: passo 8, imagem 1 %32
    • Loosen each of the five lug nuts on all tires by turning them counter-clockwise with a 19mm wrench.
  9. 1985-1988 Volvo 740 Tire Rotation: passo 9, imagem 1 %32
    • Remove tires by pulling directly away from car exposing brake rotors.
  10. 1985-1988 Volvo 740 Tire Rotation: passo 10, imagem 1 %32
    • Swap tires according to diagram.
  11. 1985-1988 Volvo 740 Tire Rotation: passo 11, imagem 1 %32
    • Place tires on axels.
    • Hand tighten the lug nuts with narrow end of nut towards car.
    • Finish tightening the lug nuts with 19mm Torque Wrench to a torque of 63 lb*ft.
Conclusão
Equipe
Cal Poly, Team 3-28, Regan Fall 2010 Membro de Cal Poly, Team 3-28, Regan Fall 2010
CPSU-REGAN-F10S3G28
Membros da 4
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 2,603
