Ir para o conteúdo principal
1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance
O que você precisa
  1. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance, 1985-1988 Volvo 740 Preparing Car For Work: passo 1, imagem 1 %32 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance, 1985-1988 Volvo 740 Preparing Car For Work: passo 1, imagem 2 %32
    • Firstly Disconnect battery
    • Always take the negative terminal off first.
    • '''General Tip After disconnecting the battery leave the car for about 10 mins , This lets any residual energy left in the electrical system to dissapate. It is good practise whatever the job
  2. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance, 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: passo 2, imagem 1 %32 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance, 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: passo 2, imagem 2 %32
    • Unlatch the two clasps, as outlined in the image.
    • Loosen the screw on the metal band, using a flathead screwdriver.
  3. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: passo 3, imagem 1 %32 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: passo 3, imagem 2 %32
    • Disconnect the electronic sensor from the MAF.
    • Press on the 2 latches, pulling the cable away from the sensor.
  4. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: passo 4, imagem 1 %32 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: passo 4, imagem 2 %32
    • Disconnect the rubber hose from the MAF.
    • Remove the MAF from the air filter housing.
  5. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: passo 5, imagem 1 %32
    • Steps 4-6 are for cleaning only.
    • Spray the MAF cleaner along the direction of travel, shown by the arrow on top of the sensor.
    • (Mass Air Flow sensor Cleaner)
  6. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: passo 6, imagem 1 %32 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: passo 6, imagem 2 %32
    • Clean the electronic coupling with an electronics cleaner.
  7. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: passo 7, imagem 1 %32 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: passo 7, imagem 2 %32
    • Inject conducting lubricant into the MAF sensor electronic coupling.
  8. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: passo 8, imagem 1 %32 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: passo 8, imagem 2 %32 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: passo 8, imagem 3 %32
    • Reattach the MAF to the air filter housing and the intake hose.
    • Tighten the screw on the metal band.
    • Latch the clasps on either side of the MAF.
  9. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: passo 9, imagem 1 %32
    • Reattach the electronic cable to the MAF.
Conclusão
Isaac Nitschke
Membro desde: 10/11/10
67 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 3-28, Regan Fall 2010 Membro de Cal Poly, Team 3-28, Regan Fall 2010
CPSU-REGAN-F10S3G28
Membros da 4
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 12
Últimos 30 dias: 28
Duração total: 9,646
