Introdução
Change the oil in your '84-'88 Toyota Pickup, with 2.4L I4 engine, to improve engine performance and longevity.
It is typically recommended that you change your vehicle's oil every 3,000 miles for extreme running conditions. However, this number can vary depending on your operating conditions, age of your vehicle, number of miles on your engine and your driving habits. Use of synthetic oils can help reduce engine wear and are advisable for older engines or if your typical driving involves extended periods of stop and go traffic.
  1. Begin by locating the 14 mm hex oil drain plug. The drain plug is on the driver's side of the truck, facing the differential case. Place the oil drain pan under the oil drain plug.
    • Begin by locating the 14 mm hex oil drain plug. The drain plug is on the driver's side of the truck, facing the differential case.
    • Place the oil drain pan under the oil drain plug.
    • Be sure to position the drain pan so that it will catch the oil when it is streaming out of the pan.
  2. Always wear protective gloves and eyewear when working with motor oil. Be careful if your car has been running recently as the engine, transmission and exhaust may be very hot. Keep rags or towels nearby to wipe up any spills. Use a 14 mm box end wrench to loosen the oil drain plug by turning it counter-clockwise until you can turn it by hand. Finish removing the oil drain plug by hand to allow the oil to drain.
    • Always wear protective gloves and eyewear when working with motor oil. Be careful if your car has been running recently as the engine, transmission and exhaust may be very hot. Keep rags or towels nearby to wipe up any spills.
    • Use a 14 mm box end wrench to loosen the oil drain plug by turning it counter-clockwise until you can turn it by hand.
    • Finish removing the oil drain plug by hand to allow the oil to drain.
    • Watch the draining oil for shiny specks. The shiny specks may be metal flakes and could mean that there is a serious problem with your engine internals.
  3. Clean the drain plug and inspect the drain plug and gasket for damage.
    • Clean the drain plug and inspect the drain plug and gasket for damage.
    • Replace the drain plug or gasket if they are damaged.
  4. Once the draining oil has slowed to a drip, clean the area around the drain plug hole with a clean towel or rag and replace the oil drain plug. Screw in the oil drain plug by hand, turning it clockwise as far as possible. Finish tightening the drain plug by using a 14 mm box end wrench. Only tighten the drain plug until it is snug. Over-tightening the oil drain plug can strip the threads or crack the oil pan.
    • Once the draining oil has slowed to a drip, clean the area around the drain plug hole with a clean towel or rag and replace the oil drain plug.
    • Screw in the oil drain plug by hand, turning it clockwise as far as possible. Finish tightening the drain plug by using a 14 mm box end wrench.
    • Only tighten the drain plug until it is snug. Over-tightening the oil drain plug can strip the threads or crack the oil pan.
    • Wipe off any oil that may have dripped onto the differential case with a clean rag or towel.
  5. Locate the hood release lever. It is below the driver's console, on the left. Pull the lever until you hear the hood click. Go to the front of the truck and locate the hood release latch. It is under the hood and slightly towards the driver's side of the truck.
    • Locate the hood release lever. It is below the driver's console, on the left.
    • Pull the lever until you hear the hood click.
    • Go to the front of the truck and locate the hood release latch. It is under the hood and slightly towards the driver's side of the truck.
    • Lift up on the hood release latch with one hand and lift the hood open with the other.
    • Place the end of the hood prop rod into the hole on the driver's side of the hood marked by an arrow.
  6. Free shipping on all orders over US$100 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  7. Observe the engine from the passenger side of the engine bay. Look between the pairs of inlet pipes on the side of the engine to find the oil filter. Use your hand to turn the oil filter counter-clockwise until it comes off the engine's oil filter threads. If the filter is too tight to turn by hand, use an oil filter wrench. A wrench that fits over the top of the oil filter is necessary as there is very little space on the sides of the oil filter.
    • Observe the engine from the passenger side of the engine bay. Look between the pairs of inlet pipes on the side of the engine to find the oil filter.
    • Use your hand to turn the oil filter counter-clockwise until it comes off the engine's oil filter threads.
    • If the filter is too tight to turn by hand, use an oil filter wrench. A wrench that fits over the top of the oil filter is necessary as there is very little space on the sides of the oil filter.
    • Pull the filter out of the engine bay with the threaded open end facing up to reduce the amount of oil spilled. Set the filter aside where it won't fall over.
  8. Dip a clean gloved finger in a bottle of new oil. Use your wetted finger to spread a thin layer of oil around the new filter's gasket.
    • Dip a clean gloved finger in a bottle of new oil.
    • Use your wetted finger to spread a thin layer of oil around the new filter's gasket.
    • Wipe off any excess oil from your hands/fingers when you are done as the oil may make handling the filter or tools difficult.
  9. Place the threaded end of the oil filter onto the engine's oil filter threads, being careful to not get dirt or debris on the filter's gasket.
    • Place the threaded end of the oil filter onto the engine's oil filter threads, being careful to not get dirt or debris on the filter's gasket.
    • Turn the filter clockwise by hand until it is snug.
    • If the filter is difficult to turn at the beginning of its threads, stop! You may be cross threading the oil filter. Re-align the oil filter and try again.
    • Do not over-tighten your oil filter by using a wrench. Doing so may cause the oil filter seal to leak and will make removing the oil filter very difficult in the future.
    • Remove the oil drain pan from under the truck.
  10. Locate the oil filler cap. It is on the valve cover, along the cover's center line and towards the front. Turn the cap counter-clockwise and remove it. Place a funnel in the oil filler hole.
    • Locate the oil filler cap. It is on the valve cover, along the cover's center line and towards the front.
    • Turn the cap counter-clockwise and remove it.
    • Place a funnel in the oil filler hole.
  11. Pour 4 quarts of oil into the engine. Use one hand to stabilize the funnel to help prevent spills. We chose 10W-30 engine oil for this oil change.
    • Pour 4 quarts of oil into the engine. Use one hand to stabilize the funnel to help prevent spills. We chose 10W-30 engine oil for this oil change.
    • Consult your owner's manual if you think your operating conditions call for a different oil viscosity.
  12. Remove the funnel and place the oil filler cap over the oil filler hole.
    • Remove the funnel and place the oil filler cap over the oil filler hole.
    • Twist the cap clockwise until it is snug.
  13. Locate the oil dipstick. It is a long metal rod with a loop on the end and is just to the right of the oil filler cap. Pull out the oil dipstick, wipe it off, place it all the way back into its hole and remove it again. Check the oil level on the end of the dipstick. It should be within the cross-hatched area, or slightly above it.
    • Locate the oil dipstick. It is a long metal rod with a loop on the end and is just to the right of the oil filler cap.
    • Pull out the oil dipstick, wipe it off, place it all the way back into its hole and remove it again.
    • Check the oil level on the end of the dipstick. It should be within the cross-hatched area, or slightly above it.
    • This is not your actual oil level, but a pre-check to make sure the engine will not run dry when you first start it. The oil level will drop slightly after the first run when oil fills the new oil filter.
    • Add oil if the oil level is below the cross hatched area of the dipstick. Place the oil dipstick all the way back in its hole.
  14. Support the hood with one hand and use your other hand to place the hood prop rod back into its holder. Make sure the hood prop rod is secured in its holder to prevent damage.
    • Support the hood with one hand and use your other hand to place the hood prop rod back into its holder.
    • Make sure the hood prop rod is secured in its holder to prevent damage.
    • Gently lower the hood until it clicks into the secondary latch.
    • Press firmly on the edge of the hood until you hear the primary latch engage.
  15. Start the truck and look for leaks underneath it. If there are leaks, shut the truck off and determine if the drain plug or filter need to be tightened, or if a part has been damaged. After running the engine for a few minutes, let it cool down for at least an hour and re-check the oil level. If the oil level is more than a 1/2" above the top hole of the dipstick you will need to drain oil. If the oil level is below the bottom hole of the dipstick you will need to add oil.
    • Start the truck and look for leaks underneath it. If there are leaks, shut the truck off and determine if the drain plug or filter need to be tightened, or if a part has been damaged.
    • After running the engine for a few minutes, let it cool down for at least an hour and re-check the oil level. If the oil level is more than a 1/2" above the top hole of the dipstick you will need to drain oil. If the oil level is below the bottom hole of the dipstick you will need to add oil.
    • Place the old oil filter in the oil drain pan with its open end facing down and allow 12-24 hours for all the oil to drain out of your old oil filter.
    • Take your old oil and filter to a recycling facility. Most auto parts stores and repair shops accept these at no charge. In addition, some cities and/or counties have a service where they will collect used oil and filters from your home. For more information, see the American Petroleum Institute's web page on used motor oil collection and recycling.
Linha de Chegada
4 outras pessoas concluíram este guia.
Phillip Takahashi
75.790 reputação
85 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 23
Últimos 7 dias: 187
Últimos 30 dias: 863
Todo: 45,258
