Introdução
Use this guide to install a new oxygen sensor. Oxygen sensors on this vehicle wear out about every 60,000 miles. Replacing an old sensor will help your car run better and stronger while warm and will provide better fuel economy.
The specific oxygen sensor part number varies among the 318i, 325e, 325i, and 318is models, so be sure you have the right sensor for your car before you start the job.
O que você precisa
Start by locating the oxygen sensor connector. On this 325i, it is a circular connector located behind the passenger side shock tower and below the (unused) battery tray.
Since this particular oxygen sensor can be used on many vehicles, the cable is a bit too long for this particular vehicle.
Luckily, Bosch is awesome and includes two zip ties to keep the cable folded on itself to take up any slack.
Fold the cable on itself and use zip ties to keep it folded. Trim the ends of the zip ties if you desire.
You did it! Enjoy your new found increase in gas mileage!
3 outras pessoas executaram este guia.
