Ir para o conteúdo principal
1976 Mercedes-Benz 230.6 Window Regulator Replacement
O que você precisa
Vídeo de Apresentação
  1. 1976 Mercedes-Benz 230.6 Window Regulator Replacement, Establishing shot: passo 1, imagem 1 %32 1976 Mercedes-Benz 230.6 Window Regulator Replacement, Establishing shot: passo 1, imagem 2 %32
    • Today's patient, the 1976 230.6, this guide will apply to any W114 or W115 from 1973 onwards (facelift)
  2. 1976 Mercedes-Benz 230.6 Window Regulator Replacement, Latch surround: passo 2, imagem 1 %32 1976 Mercedes-Benz 230.6 Window Regulator Replacement, Latch surround: passo 2, imagem 2 %32
    • Remove the two phillips #2 screws
  3. 1976 Mercedes-Benz 230.6 Window Regulator Replacement, Door opening lever surround trim: passo 3, imagem 1 %32 1976 Mercedes-Benz 230.6 Window Regulator Replacement, Door opening lever surround trim: passo 3, imagem 2 %32 1976 Mercedes-Benz 230.6 Window Regulator Replacement, Door opening lever surround trim: passo 3, imagem 3 %32
    • Pry out the black plastic cup behind the door lever, using your pick or flat-head screwdriver
    • Then remove the single phillips #2 bolt, taking care to retain the lockwasher
  4. 1976 Mercedes-Benz 230.6 Window Regulator Replacement, Door pull-closed handle: passo 4, imagem 1 %32 1976 Mercedes-Benz 230.6 Window Regulator Replacement, Door pull-closed handle: passo 4, imagem 2 %32 1976 Mercedes-Benz 230.6 Window Regulator Replacement, Door pull-closed handle: passo 4, imagem 3 %32
    • There are a total of three phillips #3 bolts holding the handle to the door, two at the bottom, and a single one at the top
    • Your phillips #2 screwdriver will work fine here, but you could use a #3 if you want
    • For the top bolt there is a chrome trim covering it. You'll need to pry back gently - using a pick or small screwdriver so as to leave it undamaged
  5. 1976 Mercedes-Benz 230.6 Window Regulator Replacement, Checkpoint reached!: passo 5, imagem 1 %32 1976 Mercedes-Benz 230.6 Window Regulator Replacement, Checkpoint reached!: passo 5, imagem 2 %32
    • You've removed the two surrounds, and the door handle
    • There are two metal garnishes above each lower-leg of the door handle, I like to arrange them so I know where they went - for later reassembly
  6. 1976 Mercedes-Benz 230.6 Window Regulator Replacement, Window winder handle: passo 6, imagem 1 %32 1976 Mercedes-Benz 230.6 Window Regulator Replacement, Window winder handle: passo 6, imagem 2 %32 1976 Mercedes-Benz 230.6 Window Regulator Replacement, Window winder handle: passo 6, imagem 3 %32
    • Looking down almost behind the window winder handle, you can see the trim panel has a bent-metal clip, the trim also acts as the locking-clip to hold the handle on
    • First push the trim panel outwards toward yourself
    • Then it slides away from the hub, towards the knob which you hold to rotate the handle
  7. 1976 Mercedes-Benz 230.6 Window Regulator Replacement, Door interior trim panel: passo 7, imagem 1 %32 1976 Mercedes-Benz 230.6 Window Regulator Replacement, Door interior trim panel: passo 7, imagem 2 %32 1976 Mercedes-Benz 230.6 Window Regulator Replacement, Door interior trim panel: passo 7, imagem 3 %32
    • The interior door trim panel is held in place by a series of push-pins around the edge of the panel, you can pry them out using a plastic trim tool, or like I did here with a small prybar and rag
    • To avoid damaging the trim or the door, try to get the pry tool as close as possible to each clip then gently pry until it pops out
    • The trim panel separates below the top portion, so the lock-knob and window seal can remain in-place and undisturbed
    • Remember the trim panel is very-fragile and made of particle-wood, so handle it gently and place it out of harms way while you're working on the door
  8. 1976 Mercedes-Benz 230.6 Window Regulator Replacement, Moisture or vapour barrier: passo 8, imagem 1 %32 1976 Mercedes-Benz 230.6 Window Regulator Replacement, Moisture or vapour barrier: passo 8, imagem 2 %32
    • Peel back the vapour/moisture barrier plastic, mine was removed before, so the original glue was gone, I had some spots of double-sided tape holding it in
    • I just fed it through the partially-open window to hold it back, but if it's windy it might be annoying
    • We're trying to gain access to the door interior
  9. 1976 Mercedes-Benz 230.6 Window Regulator Replacement, Nasty parts suprise: passo 9, imagem 1 %32 1976 Mercedes-Benz 230.6 Window Regulator Replacement, Nasty parts suprise: passo 9, imagem 2 %32 1976 Mercedes-Benz 230.6 Window Regulator Replacement, Nasty parts suprise: passo 9, imagem 3 %32
    • My new part (1157251102) looked so full of promise with it's blue genuine parts label, and it's shiny metal it's manufacture date stamped 10/1987
    • However the installation was about to take a turn for the worse, I didn't realise at first, naively thinking a genuine part would just bolt-on
    • It turns out my new part didn't have threads tapped in the four bolt holes!
    • Can you believe it!?
    • So with a bit of cursing, I dragged out my tap and die set
    • If you get lucky you won't need to tap the holes on your replacement regulator
  10. 1976 Mercedes-Benz 230.6 Window Regulator Replacement, Regulator arm to window bottom track: passo 10, imagem 1 %32 1976 Mercedes-Benz 230.6 Window Regulator Replacement, Regulator arm to window bottom track: passo 10, imagem 2 %32 1976 Mercedes-Benz 230.6 Window Regulator Replacement, Regulator arm to window bottom track: passo 10, imagem 3 %32
    • The arm that attaches to the bottom of the window uses a pin with clip and special washer
    • It's a bit fiddly since you can't see it easily, mostly you'll be working by feel, the clip slides into a groove machined into the tip of the pin
    • There is a rectangular plastic bushing that slides in the window-bottom track, it fits over the pin first
    • Then the pin and bushing go through the track
    • Then there is a plastic slightly-conical flat washer with a metal star-shaped washer that fits over that
    • Then at the very tip of the pin - facing into the door, there is a spring-steel clip
    • I used a pick and a flathead screwdriver and a pair of needlenose pliers and a bit of cursing to get it out and back in
    • NOTE: the window drops after you pull out the pin, since nothing is holding it up - I put a small prybar in place to hold it up, but you could also use a piece of wood or whatever
  11. 1976 Mercedes-Benz 230.6 Window Regulator Replacement, Regulator to door bolts: passo 11, imagem 1 %32 1976 Mercedes-Benz 230.6 Window Regulator Replacement, Regulator to door bolts: passo 11, imagem 2 %32 1976 Mercedes-Benz 230.6 Window Regulator Replacement, Regulator to door bolts: passo 11, imagem 3 %32
    • There are four bolts (circled in blue) holding the regulator to the door, they are all 10mm head bolts, but the top two are longer
    • I used a 10mm deep socket on a 1/4 inch ratchet, but any 10mm wrench, spanner, or socket should work
    • in the second picture you can see the gear-quadrant of my old regulator hanging down, it's supposed to be up engaged in the winder gear teeth
    • It was at this point that I realised I could not get the old regulator past the window vertical track...
    • Notice I'm using a short prybar to prop up the window now (since otherwise it drops down) you could use a piece of wood or some other tool as well
  12. 1976 Mercedes-Benz 230.6 Window Regulator Replacement, Front vertical window track: passo 12, imagem 1 %32 1976 Mercedes-Benz 230.6 Window Regulator Replacement, Front vertical window track: passo 12, imagem 2 %32 1976 Mercedes-Benz 230.6 Window Regulator Replacement, Front vertical window track: passo 12, imagem 3 %32
    • Since you can't get the regulator out past the window track, it has to be detached temporarily
    • It's held on by two 10mm bolts, which have fancy dimpled flat washers, and lock washers, I've circled them in green in the picture
    • Remove those two bolts, which should give you enough movement to push that window track forward off the window a bit, then into the door a bit deeper
    • At this point it should be possible to pull out the window regulator, angling it as you go to avoid jamming on things
  13. 1976 Mercedes-Benz 230.6 Window Regulator Replacement, Preparing new parts: passo 13, imagem 1 %32 1976 Mercedes-Benz 230.6 Window Regulator Replacement, Preparing new parts: passo 13, imagem 2 %32 1976 Mercedes-Benz 230.6 Window Regulator Replacement, Preparing new parts: passo 13, imagem 3 %32
    • As I mentioned in step 9, I was punished by the lack of threads in my new window regulator
    • So I broke out my tap and die set, and checked the bolt thread pitch, which was metric M6 x 1.0
    • I didn't notice until I'd already slipped my new part into the door... I actually pulled it back out of the door to tap the four holes
    • If your part also has a lack of threads in the holes, be sure to check it before you've put the clip through the pin, and reinstalled the track bolts etc
  14. 1976 Mercedes-Benz 230.6 Window Regulator Replacement, Fitting the new regulator: passo 14, imagem 1 %32 1976 Mercedes-Benz 230.6 Window Regulator Replacement, Fitting the new regulator: passo 14, imagem 2 %32 1976 Mercedes-Benz 230.6 Window Regulator Replacement, Fitting the new regulator: passo 14, imagem 3 %32
    • Install several of the regulator bolts (remember the top two are the long ones)
    • Don't tighten them yet
    • Grease up the window bottom track and bushings before assembling
    • The bushing clip is pretty hard to get on - enjoy that
    • After you're happy with the placement tighten the bolts
    • Then remember to put the vertical window track bolts back in too - they have the funny dimpled flat washers (be sure the window glass is in the track)
    • Follow the steps backwards to reassemble the door
Conclusão
Gaspard Leon
Membro desde: 04/24/10
2.831 Reputação
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 41
Duração total: 2,368
