Ir para o conteúdo principal
1 - Kettle - The different functions
  1. 1 - Kettle - The different functions, What are the functions of a kettle?: passo 1, imagem 1 %32 1 - Kettle - The different functions, What are the functions of a kettle?: passo 1, imagem 2 %32
    • The kettle is a kitchen utensil used to bring a liquid to a boil. Electric kettles, which are the subject of this study, have a built-in heater.
    • The most common models are the cordless kettles: the kettles are placed on a base (see photo) connected to an electrical outlet, during the heating phase. The container can then be detached from the base and used as an ordinary container.
    • The operation of the electric kettle is based on the Joule effect. The kettles are equipped with a heating resistor in the form of a ring-shaped tube. The current, when it passes through the resistor, causes an increase in the thermal energy of the ring: the water is heated by heat transfer.
    • To learn more about the Joule effect, visit this site. See also the definition of a "kettle" on Wikipedia
  2. 1 - Kettle - The different functions, Description: passo 2, imagem 1 %32 1 - Kettle - The different functions, Description: passo 2, imagem 2 %32 1 - Kettle - The different functions, Description: passo 2, imagem 3 %32
    • Our study is of the Moulinex brand model AC10-10S011. It is 1100W.
    • The device consists of a base 1 and a container 2. The base is equipped with a power cord. It is equipped with a device 3 which ensures the electrical continuity with the heating resistor which is in the container. This device is secured to avoid any contact with the electrical conductors.
    • In the tank is a heating element 4. A switch allows to start and stop the heating. This kettle is also equipped with an automatic stop when the water has reached the right temperature.
Conclusão
We now know what a kettle is and what its different functions are. We can move on to the study of its operation in the following guide: "a kettle, how does it work?"“Kettles, how do they work?”
7 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
fr en
100%
shingle está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Atelier Soudé
Membro desde: 12/13/18
3.691 Reputação
Autoria de 15 guias
Equipe
Atelier Soudé Membro de Atelier Soudé
Local Repair Groups
Membros da 5
Autoria de 30 guias
Um comentário
Hi evry bary 'i m for algeria and i want working whith you so if you ar iteressed send me a messaga message please
Belmokdad Idir - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 13
Últimos 30 dias: 49
Duração total: 4,413
