Ir para o conteúdo principal
Removing factory feet from a Mac Laptop (Non-Retina)
O que você precisa
  1. Removing factory feet from a Mac Laptop (Non-Retina), Remove the bottom cover: passo 1, imagem 1 %32 Removing factory feet from a Mac Laptop (Non-Retina), Remove the bottom cover: passo 1, imagem 2 %32
    • I am using a 2011 13" MacBook Pro. Most machines are similar, but variations may exist.
    • If possible, disconnect the battery to protect your components once the bottom is removed.
    • Remove the bottom cover of your MacBook with the guide for your specific system.
  2. Removing factory feet from a Mac Laptop (Non-Retina), Removing failed feet: passo 2, imagem 1 %32 Removing factory feet from a Mac Laptop (Non-Retina), Removing failed feet: passo 2, imagem 2 %32 Removing factory feet from a Mac Laptop (Non-Retina), Removing failed feet: passo 2, imagem 3 %32
    • Before removing the good feet, remove the failed feet first. These may come off without disassembly if they have fully failed.
    • After removing the damaged feet, remove the intact feet. Follow the disassembly guide for your specific Mac.
  3. Removing factory feet from a Mac Laptop (Non-Retina), (Full set replacement only) Removing intact feet: passo 3, imagem 1 %32 Removing factory feet from a Mac Laptop (Non-Retina), (Full set replacement only) Removing intact feet: passo 3, imagem 2 %32 Removing factory feet from a Mac Laptop (Non-Retina), (Full set replacement only) Removing intact feet: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    iFixit Opening Picks (Set of 6)
    Comprar
    • To remove the intact feet, score the internal plug. Once scored, remove the plug with a guitar pick.
    • After removing the inner plug, push the foot out with a spudger or screwdriver.
  4. Removing factory feet from a Mac Laptop (Non-Retina), Install the new feet: passo 4, imagem 1 %32 Removing factory feet from a Mac Laptop (Non-Retina), Install the new feet: passo 4, imagem 2 %32
    Adhesive Cleanup Kit (Set of 12)
    Comprar
    • If the adhesive ring remains, remove it first. Clean the chassis with denatured alcohol or adhesive cleaner.
    • After removing the old feet, install the new set onto the bottom cover.
    • Re-install the cover on the computer.
Linha de Chegada
4 outras pessoas executaram este guia.
Nick
Membro desde: 11/10/09
88.851 Reputação
Autoria de 49 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.528 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 51
Duração total: 4,360
