Introdução
Hardware Requirements
Processor
Release Year (Non-Negotiable)
- Recommended: 2011-2012
- Minimum: 2008
Technical Requirements (Non-Negotiable)
- 64-Bit
- Acceptable: Dual Core
- Recommended: Quad Core
Processor (Negotiable)
- Intel
- Value: (Sandy Bridge) Core i5
- Low cost: (Sandy Bridge) Core i3
- AMD
- Value
- (APU) Comal Fusion (Socket FS1r2/FP2)
- (Non APU) Turion II Dunabe (Socket S1G4)
- Low Cost
- (APU) Sabine (Socket FS1)
- (Non APU) Athlon II Dunabe (Socket S1G4)
- Value
Memory (Non-negotiable)
DDR3 is easier to find then DDR2.
- Minimum: 4GB
- Recommended: 8-16GB
SSD/HDD (Negotiable)
- SSD
- Minimum: 256GB
- Recommend: 512GB
- HDD
- Minimum: 500GB
- Recommend: 1TB
Miscellaneous
Non-Free firmware requirements (Integrated)
- Intel
- Intel HD Graphics: N/A
- Intel GMA: Required for PowerVR chipsets (GMA 500/600/3600/3650)
- AMD
- AMD Radeon G Series: Non-Free firmware required.
- AMD Radeon HD: Non-Free firmware required.
Non-Free firmware requirements (Dedicated)
- AMD and nVidia require Non-Free firmware. Open source firmware may degrade performance or cause problems.
Laptop battery recalibration (Optional)
Refer to this guide if your laptop includes an older battery. This is optional but highly recommended.
Ferramentas
Model:
Processor: Intel Core i5 2nd/3rd gen XXXXM/QM
Graphics: Intel HD Graphics 3000/4000
RAM: 8/16/32GB (DDR3/L)
Storage: (SSD/HDD)
Networking
Ethernet:
WiFi:
Press Esc/F12 to access the BIOS or F10/F11 for the One-time boot menu.
Press the right arrow on your keyboard. Find System Configuration.
In System Configuration, select Boot Options. Make the following changes:
Disable Secure Boot. Press Enter and select Disabled. If needed, disable Legacy Boot.
Save the change and reboot your system.
*buntu covers Ubuntu and other flavors. Each release is similar, but system requirements vary. Support period: 3-5 years (LTS)/6 months (Rolling release).
Linux Mint is Ubuntu derived. Referral links are used for revenue. Support period: 4 years.
LMDE is Debian derived. It is not PPA compatible and receives fewer releases.
Debian is an intermediate distro, often used as a base distro. Support period: 5 years.
Budget: Recommended: WD Blue 1TB. WD Blue drives do not last as long.
7mm: Recommended: WD Black 500GB.
9.5mm: Recommended: WD Black 1TB.
250-320GB hard drives are typically heavily used.
500GB-1TB hard drives <5 years old are generally serviceable. Drives >5 year old are likely to fail.
DVD Recorder drives are the most common. DVD±R drives read both formats.
Blu-Ray drives are primarily user installed.
Core i Series 3rd gen (Ivy Bridge) systems are becoming common. However, they tend to be more expensive.
Core i Series 2nd gen (Sandy Bridge) systems are common and affordable.
Pentium (Sandy/Ivy Bridge) systems are low end, but better than Celeron systems. These are difficult to recommend.
While Core i Series 1st gen (Arrandale) systems are usable, the onboard graphics are subpar. Consider a Pentium laptop.
Core 2 Duo systems are still usable for basic tasks. It is typically cheaper to replace the entire system if it has a major failure.
The Comal (Fusion) (2012) platform was designed for mainstream laptops. All processors are dual or quad core. This platform uses Radeon 7XXXG Series graphics.
The Sabine (Fusion) (2011) platform was designed for mainstream laptops. Try to avoid E2/A4 laptops. This platform uses Radeon 6XXXG Series graphics.
The Brazos (2011) platform was designed for netbooks. All processors are dual core except the C30/E-240. This platform uses Radeon HD 6000 Series graphics.
The Danube (2010) platform was designed for mainstream notebooks. All processors are dual or quad core except the V Series. This platform uses Radeon HD 4200 Series graphics.
The Nile (2010) platform is designed for Ultrathin laptops. All processors are dual core except the Athlon II K125/K145/V105. This platform uses Radeon HD 4200 Series graphics.
The Tigris (2009) platform was designed for mainstream laptops. All processors are dual core except the Sempron M100/120/140. This platform uses Radeon HD 4200 Series graphics.
The Congo (2009) platform was designed for Ultraportable laptops. There are no single core processors. This platform uses Radeon HD 3200 Series graphics.
AMD
AMD Radeon GPUs are marketed towards consumers. While Linux support is better, some features are not supported.
AMD FirePro GPUs are made for ISV certified workstations. These cards provide full Linux support.
nVidia
nVidia GeForce GPUs are known for subpar Linux compatibility. nVidia focuses on proprietary API support (DirectX, PhysX, GameWorks). This may impact performance.
nVidia Quadro GPUs are made for ISV certified workstations. These cards provide full Linux support.
Intel wireless cards work well in Linux. Some distros do not include the firmware required (Non-Free) on official images.
QCA/Atheros wireless cards work well in Linux and are usually easily configured. ath10k cards require Non-Free firmware.
Azurewave wireless card compatibility is primarily chipset based. ath10k cards are the most compatible.
Realtek wireless cards work best in *buntu and Linux Mint. Compatibility varies in other distros. Some distros do not include the firmware required (Non-Free) on official images.
Dell laptops are not whitelisted. Factory Intel laptops provide the best out of the box support.
Alienware (Dell) laptops are not whitelisted. Some Killer Wireless cards have problems in Linux.
Acer laptops are not whitelisted.
Asus Asus laptops are not whitelisted.
MSI laptops are not whitelisted. Some Killer Wireless cards have problems in Linux.
Samsung laptops are not whitelisted. Most laptops ship with Intel or Broadcom wireless.
Private label laptops are manufactured by ODM's (Ex: Clevo/Sager) for companies like System76. These are typically not whitelisted.
Lenovo laptops from this period are whitelisted. POST will halt with an 1802 error. Some laptops may boot with the card disabled.
HP Business (2004-2012) laptops are whitelisted. 2013+ laptops are unaffected, but older models remain whitelisted.
HP Consumer (2007-present) laptops have been whitelisted since 2007. Current models remain whitelisted.
Some LG laptops have a whitelist. Research the laptop you are considering if this matters.
Intel Outside of a few obscure chipsets, most Intel chipsets work without any issues.
AMD chipsets are primarily found on OEM systems and high end boards. Most motherboards use a VIA chipset.
VIA chipsets are known for excellent Linux compatibility. This is primarily because VIA provides firmware for Linux. Distros like Debian typically require manual firmware installation.
nVidia nForce nVidia left the chipset market in 2010, but these systems are still out there. These chipsets require Non-Free firmware.
Uma outra pessoa concluiu este guia.
