Ir para o conteúdo principal
Samsung Galaxy S8 SIM Card Tray Replacement
O que você precisa
  1. Samsung Galaxy S8 SIM Card Tray Replacement, SIM Card: passo 1, imagem 1 %32 Samsung Galaxy S8 SIM Card Tray Replacement, SIM Card: passo 1, imagem 2 %32 Samsung Galaxy S8 SIM Card Tray Replacement, SIM Card: passo 1, imagem 3 %32
    • Insert a SIM card opening tool into the small hole on the left side of the top edge of the phone.
    • Press to eject the tray.
    • Remove the SIM card tray from the phone.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
Conclusão
After you've completed the repair, follow this guide to test your repair.
8 outras pessoas executaram este guia.
Adam O'Camb
Membro desde: 04/11/15
196.299 Reputação
Autoria de 416 guias
5 comentários
Is this sim tray water proof with the rubber seal or no?
And what colors does it come in?
Darryl Bass - Responder
Is the Galaxy S8 similar to the Galaxy S8+ ?
travislwright2016 - Responder
Is installing the SIM card in the Galaxy S8 similar to installing the SIM card into the Galaxy S8+ ?
My tray actually broke off inside it, I could not remove it far enough to even get the sim card in it, only the sd card, is there a way to open it up?
Eric Hogarth - Responder
Did you find a way?
Jonathan Tsikire -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 22
Últimos 7 dias: 99
Últimos 30 dias: 379
Duração total: 36,300
