Ir para o conteúdo principal
iMac Intel 24" EMC 2134 and 2211 Glass Panel Replacement
O que você precisa
  1. iMac Intel 24" EMC 2134 and 2211 Glass Panel Replacement, Glass Panel: passo 1, imagem 1 %32 iMac Intel 24" EMC 2134 and 2211 Glass Panel Replacement, Glass Panel: passo 1, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    Comprar
    • The glass panel is fixed onto the front bezel with fourteen magnets around its perimeter.
    • Stick two suction cups to opposing corners of the glass panel.
    • To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
    • If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent such as Windex.
  2. iMac Intel 24" EMC 2134 and 2211 Glass Panel Replacement: passo 2, imagem 1 %32
    • Gently pull the glass panel straight up off the iMac.
    • The glass panel has several positioning pins around its perimeter. To avoid shearing these pins off the glass panel, be sure to only pull straight up during removal.
    • Be meticulous about cleaning the LCD and the inside face of the glass panel before reinstallation, as any fingerprints or dust trapped inside will be annoyingly visible when the display is on.
Conclusão
32 outras pessoas executaram este guia.
Brittany McCrigler
Membro desde: 03/05/12
89.012 Reputação
Autoria de 131 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.763 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 38
Duração total: 18,994
