Ir para o conteúdo principal
Kindle Voyage Battery Replacement
O que você precisa
  1. Kindle Voyage Battery Replacement, Back Panel: passo 1, imagem 1 %32 Kindle Voyage Battery Replacement, Back Panel: passo 1, imagem 2 %32
    • Insert a plastic opening tool between the plastic panel shown on the device.
    • Use the tool to pry the plastic away from the device.
    • There will be adhesive holding this piece of plastic to the device. You may have to pull pretty hard to get it separated.
  2. Kindle Voyage Battery Replacement: passo 2, imagem 1 %32
    • Use an aluminum driver attached with a Phillips head size #00 to remove the four 3mm screws shown in the picture. For reassembly, note that the top two and bottom two screws are different sizes.
  3. Kindle Voyage Battery Replacement: passo 3, imagem 1 %32 Kindle Voyage Battery Replacement: passo 3, imagem 2 %32 Kindle Voyage Battery Replacement: passo 3, imagem 3 %32
    • Once the screws are removed, the back panel can slide off the device.
  4. Kindle Voyage Battery Replacement: passo 4, imagem 1 %32 Kindle Voyage Battery Replacement: passo 4, imagem 2 %32
    • Remove the magnetic component with the magnetic head of the aluminum driver.
  5. Kindle Voyage Battery Replacement, Battery: passo 5, imagem 1 %32 Kindle Voyage Battery Replacement, Battery: passo 5, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Plastic Cards
    $2.99
    Comprar
    • Use a plastic card to pry the battery away from the device.
    • Gently un-clip the battery plug from the device and remove the battery.
Conclusão
27 outras pessoas executaram este guia.
Sean Yap
Membro desde: 01/22/15
1.253 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 19-12, Maness Winter 2015 Membro de Cal Poly, Team 19-12, Maness Winter 2015
CPSU-MANESS-W15S19G12
Membros da 5
Autoria de 8 guias
15 comentários
Where can I buy a replacement buttery for my kindle voyage?
hegi88 - Responder
Where to find a replacement battery for kindle voyage 3G please if any one knows
Himadri Endow - Responder
Bump. Cannot seem to procure a new battery for the Kindle Voyage. Nice to know how to replace the old one; just need something to replace it WITH! Thanks for any hints on finding one. Battery model number is: MC-305070, 3.8V 1320mAh/5.01Wh, P/N 58-000056
larryg - Responder
Any advance on where one can find a replacement battery for the Kindle Journal?
Charles WRIGHT - Responder
Still looking for a source for this battery.
Neil Hall - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 17
Últimos 7 dias: 118
Últimos 30 dias: 506
Duração total: 27,126
