iPad Mini 2 Teardown
11 respostas 7 pontos |
White Vertical Lines on the screen |
10 respostas 12 pontos |
Ipad not turning on; stuck in charging symbol during ios 11 update |
6 respostas 5 pontos |
Will the LCD from iPad mini 1 work on iPad mini 2? |
3 respostas 7 pontos |
My iPad Mini 2 display has lines on it. |
Peças
Ferramentas
Estas são algumas ferramentas comuns usadas para executar trabalhos neste dispositivo. Talvez você não precise usar todas elas em cada procedimento.
Background and Identification
Slightly thicker and heavier than the previous generation of iPad Mini, the iPad Mini 2 (iPad mini Retina) shares many of the iPad Air's specifications.
The iPad mini 2 can be identified by its model number, found on the lower rear case.
- Wi-Fi: A1489
- Wi-Fi/Cellular: A1490
- China: A1491
Specifications
Announce date: October 22, 2013
Color display: 7.9-inch Retina Display
Processor: Dual-core Apple A7 processor
Resolution: 2048-by-1536 resolution at 326 pixels per inch
Storage: 16, 32, 64 or 128 GB flash memory
Wireless: Wi-Fi (802.11a/b/g/n); dual channel (2.4GHz and 5GHz) and MIMO, with Bluetooth 4.0 and optional LTE.
Battery: Built-in 23.8-watt-hour rechargeable lithium-polymer battery (Up to 10 hours of use)
Weight: 0.73 pound (331 g)
Dimensions: 7.87 inches (200 mm) x 5.3 inches (135 mm) x 0.3 inch (7.5 mm)
Troubleshooting
- Diagnose and repair screen backlight issues with our iDevice Backlight Troubleshooting Page.
