1 Diagrama
Perguntas Populares do Fórum
Fazer uma perguntaNão há nenhuma pergunta. Seja o primeiro a fazer uma pergunta!
Modelos
R86034
Background
The Ridgid R86034 is an 18V lithium ion cordless impact driver. This tool is compact and lightweight, making it suitable for heavy duty tasks in both a professional setting and for home improvement projects. It operates using a lithium ion battery, and can deliver a maximum torque of 1,750 in-lbs. The impact driver can perform up to 3,100 impacts per minute and has a 1/4" hex chuck size. Its dimensions are 12" x 3" x 9" and it weighs 2.8 lbs without the battery. An LED worklight is incorporated into the design for work in low light conditions.
The R86034 impact driver houses a brushless motor, which contributes to its durability and power efficiency. The device comes with three speed settings, allowing the user to adjust the speed and power according to the task at hand. The tool accepts 1/4" hex shank drill and driver bits, facilitating quick bit changes without the need for a chuck key. The compact size of the tool, with a head length of only 5.5", enables it to access tight spaces. Moreover, the impact driver is designed with a belt clip for handsfree carrying and a rubber grip for comfort and slip resistance during use. The tool is primarily used for driving and removing screws, bolts, and fasteners in wood, metal, and other materials.
Technical Specifications
- Model Number: R86034
- Product Type: Impact Driver
- Power Source: 18V Lithium Ion Battery (Sold Separately)
- Maximum Torque: 1,750 in-lbs
- Impacts Per Minute: Up to 3,100
- Chuck Size: 1/4" Hex
- Dimensions: 12" x 3" x 9"
- Weight: 2.8 lbs Without Battery
- Lighting: LED Worklight
Warranty
The Ridgid R86034 Impact Driver is covered by Ridgid's lifetime service agreement. This lifetime warranty covers the tool for any defects in workmanship and materials for the entire life of the tool. However, normal wear items such as brushes, chucks, and switches are only covered for a period of 3 years from the date of purchase. Additionally, the battery and charger carry a separate warranty that lasts for 3 years. To claim the warranty, customers are expected to contact Ridgid's customer service with proof of purchase and details of the defect or issue.
