Perguntas técnicas
Fazer uma perguntaNão há nenhuma pergunta. Seja o primeiro a fazer uma pergunta!
Modelos
0880-20-
Background: The Milwaukee 0880-20 strong reliable Cordless Wet/Dry Vacuum. It sports a 6-foot flexible hose for an extended reach. A Crevice tool is also included. Utility nozzle and HEPA filter are included in the box. It has 32 inches of water lift and a 2-gallon capacity. The hose diameter is 1-1/4” for getting outdoor debris removed. With its RedLithium™ 9.0 Battery pack, it can last up to 30 minutes on a single charge. It contains a toolbox design in which it can be stacked with other boxes within the same storage dimensions. This is made with commercial materials to have extreme impact-resistant durability. The cover allows for easy cleaning. The integrated port allows for a blower function in addition to suction.
Identification: To properly identify that this is the correct device you will need to verify first with the logo located on the front side in Milwaukee’s white signature font with a white lightning bolt underneath. The colors will be jet black on the top and bottom with the middle being painted bright red. The logo should be sitting in the red middle area. There are two black latches on the front left and right side which open the unit to release the hose and two supplied nozzle attachments. You should also now see the power switch inside the back right side of the vacuum. There is a second latch to change the filter on the front bottom. Lastly, there should be a bright red handle with a black stripe on top.
Technical Specifications:
- Series: M18™
- Product no.: 0880-20
- Dimensions (W x H x D): 15.75" x 22.5" x 11.5"
- Weight: 10 pounds
- Battery voltage: 18V Lithium Ion
- Use: Wet & Dry Applications
- Maximum air flow: 45 CFM
- Sealed suction in water lift: 32″
- Hose Diameter: 1-1/4″
- Capacity: 2 Gallons
- Warranty: 5 Year Limited
- Device only: Batteries and chargers are not included.
- Runtime:30 minutes on a full charge
- Included: Hose
- Included: Utility Nozzle
- Included: Crevice Tool
- Included: HEPA Filter
- Design: Stackable toolbox
- Integrated: Blower port
- Compatibility: Milwaukee 18V batteries. (Slide-on)
- Water Lift: 32”
- Air Velocity: 45 MPH
Additional Information:
1. Operators’ manual detailing all safety, maintenance, and technical information.
MILWAUKEE ELECTRIC TOOL CORPORATION. (2013, June). Milwaukee OPERATORS MANUAL. Retrieved January 26, 2023, from https://documents.milwaukeetool.com/58-1...
2. Features, photos, specifications, and where to purchase one of these devices.
BC Fasteners & Tools Ltd. (2023, January). Milwaukee OPERATORS MANUAL. BC FASTENERS & TOOLS LTD. Retrieved January 25, 2023, from
3. Features, photos, specifications, and where to purchase one of these devices.
Allied Electronics & Automation, Inc, 2023 (2023, January 31). Milwaukee Electric Tool 0880-20. Www.Alliedelec.com. Retrieved January 26, 2023, from
