6 Diagramas
Perguntas Populares do Fórum
Fazer uma perguntaNão há nenhuma pergunta. Seja o primeiro a fazer uma pergunta!
Modelos
EK7651HD
Background and Identification
Makita is a Japanese power tool manufacturer that was founded in 1915. It is a leading brand of professional-grade tools. This company produces cordless tools, power tools, petrol equipment, and batteries for the cordless tools. The tools themselves range from wrenches and drills to chainsaws and lawnmowers. This cement saw may also be known by the model numbers EK7651H, EK7650H, or EK7651HDQ.
This saw is intended for professional concrete cutting use in in a variety of applications including construction work and rescue crews. The 14 inch blade is capable of cutting through concrete up to a depth of nearly five inches. This Makita power cutter uses a four-stroke engine, which doesn’t require the user to mix oil and fuel to use it and has better fuel efficiency than a two-stroke engine. However, four stroke engines aren’t always better than two stroke engines, and which one you should look for in a machine depends on what the application of the machine will be. For a detailed explanation of two-stroke engines vs four-stroke engines, you can see this explanation by the Chainsaw Journal.
Technical Specifications
- Product Length: 30-3/4"
- Product Height: 17.875"
- Product Width: 12.25"
- Wheel Diameter: 14"
- Overall Length: 30-3/4"
- Dry Weight: 28.3 lbs.
- Max. Cutting Depth: 4-13/16"
- Engine Displacement: 4.61 cu.in. (75.6 cc)
- Engine: 4.1 HP/3 kW
- Power Type: 4-stroke gas
- No Load Speed/Max. Spindle Speed: 9,100 / 4,300 RPM
- Fuel Type: Unleaded gas
- Fuel Tank Capacity: 37 oz.
- Arbor w/ Adaptor: 20mm/1" adaptor
