1 Diagrama
Perguntas Populares do Fórum
Fazer uma perguntaNão há nenhuma pergunta. Seja o primeiro a fazer uma pergunta!
Documentos
Modelos
BDT142
Background
The Makita BTD142 is a cordless impact driver designed for a range of fastening applications. It comes with a Makita-constructed 4-pole motor that delivers a maximum torque of 1,280 in.lbs. The product features a variable speed design, with a no-load speed range of 0 to 2,300 RPM and impacts per minute ranging from 0 to 3,200. The tool is compact, measuring just 5-3/4" in length and weighing only 2.9 lbs, which may help reduce operator fatigue during prolonged use.
The BTD142 is rated at 18V and uses a standard BL1815 battery cartridge. It has a 1/4" hex chuck for quick bit changes and is also equipped with a built-in LED light with afterglow to illuminate the work area. The product is designed to work with machine screws ranging from 4mm to 8mm, standard bolts from 5mm to 14mm, and high tensile bolts from 5mm to 12mm.
This product also contains a hook for temporary hanging of the tool and has provisions for carbon brush replacement for maintenance purposes. The user is advised to replace the carbon brushes when they wear down to the limit mark, and to use only identical carbon brushes. After replacing brushes, it is recommended to run the tool with no load for about 1 minute to break in the brushes.
The manufacturer, Makita, has not provided information on the product's release date or price in the document.
Technical Specifications
- Machine screw: 4 mm - 8 mm (5/32" - 5/16")
- Standard bolt: 5 mm - 14 mm (3/16" - 9/16")
- Capacities: High tensile bolt: 5 mm - 12 mm (3/16" - 1/2")
- No load speed (RPM): 0 - 2,300/min
- Impacts per minute: 0 - 3,200
- Overall length: 146 mm (5-3/4")
- Net weight: 1.3 kg ( 2.8 lbs)
- Rated voltage: D.C.18 V
- Standard battery cartridge: BL1815
