Perguntas em alta no fórum
Fazer uma perguntaNão há nenhuma pergunta. Seja o primeiro a fazer uma pergunta!
Background
The Logitech Lift Vertical Ergonomic Mouse FOR BUSINESS is a compact, right-handed vertical mouse designed to reduce wrist pronation and improve comfort for extended office use. It features a 57° vertical angle, contoured shape with soft-touch durable materials, and a textured thumb rest for secure grip. Key features include Bluetooth Low Energy and Logi Bolt wireless connectivity, an adjustable high-precision optical sensor, and programmable buttons via Logi Options+. The design emphasizes durable materials and long battery life suited for business deployments.
Identification
The Logitech Lift Vertical Ergonomic Mouse FOR BUSINESS includes Mouse (M/N MR0094) and USB receiver (M/N CU0021). Model labels are located as follows — Mouse: on the underside product label; USB Receiver: printed on the flat face or side of the receiver housing near the USB plug. Each component carries its own model (M/N) and serial (S/N) identifiers.
Specifications
- Form Factor: Right-handed vertical ergonomic mouse (57° tilt)
- Connectivity: Bluetooth Low Energy and Logi Bolt USB receiver (Logi Bolt business protocol)
- Battery: Single AA battery; up to 24 months battery life (varies with usage and connection)
- Sensor / DPI: High-precision optical sensor; adjustable 400–4,000 DPI via Logi Options+
- Buttons: 5 programmable buttons (Left, Right, Middle/Scroll, Back, Forward)
- Primary Switches: Omron mechanical switches (commonly rated ~10M clicks) for primary left/right buttons
- Physical Dimensions: Approximately 120 mm × 72 mm × 78 mm (length × width × height) — compact vertical form
- Weight: Around 135 g with battery (varies by battery chemistry)
- Compatibility: Windows, macOS, Linux (basic), and configurable via Logi Options+ on Windows/macOS
- Materials / Durability: Soft-touch plastics with textured rubber thumb rest; designed for workplace durability and extended use
Troubleshooting
Common repair-relevant faults include double-clicking/failing primary switches (diagnose by testing click continuity and looking for mechanical wear), scroll-wheel skip or looseness (inspect wheel assembly and encoder), and connectivity loss (test with Logi Bolt receiver and Bluetooth on another host). For battery/power issues, verify the AA battery and contacts; for switch faults, inspect or replace the microswitches.
For additional troubleshooting help, visit: Visit support.logi.com for drivers, Logi Options+ software, firmware updates, and enterprise deployment resources for Logi Bolt.
Additional Information
Warranty Info
Limited hardware warranty varies by region and channel; business units may include a 1- to 3-year warranty depending on purchase agreement.
