1 Diagrama
Perguntas Populares do Fórum
Fazer uma perguntaNão há nenhuma pergunta. Seja o primeiro a fazer uma pergunta!
Modelos
11602
Background
The Lincoln Electric Welder 11602 is a welding machine designed for arc welding. It uses stick welding electrodes to join various types of metals together. This welder can be powered with 240V, 1-Phase input power and has an output range of 30-125 amps. The device's duty cycle is 20% at 125 amps, and it has an open circuit voltage of 79V. The physical dimensions of the welder are 17 x 8 x 13 inches, and it weighs 19 kg.
The Lincoln Electric Welder 11602 is designed with portability in mind, incorporating a top carry handle for easier transportation. It features adjustable output control, allowing for fine-tuning of the amperage. Another feature is the quick-change drive roll, which facilitates easy switching between flux-cored and stick welding. The welder also has thermal overload protection to prevent overheating and a durable all-metal case. The Lincoln 11602 is used for general-purpose stick welding with a variety of materials, including mild steel, stainless steel, cast iron, and hard-facing electrodes. It is capable of welding up to 1/4 inch thick steel in a single pass, making it suitable for applications such as farming, auto repair, maintenance, and fabrication.
Technical Specifications
- Model Number: 11602
- Product Type: Arc Welding Machine
- Input Power: 240V, 1-Phase
- Output Range: 30-125 amps
- Duty Cycle: 20% at 125 amps
- Open Circuit Voltage: 79V
- Dimensions: 17 x 8 x 13 inches
- Weight: 19 kg
- Material Compatibility: Mild steel, stainless steel, cast iron, hard-facing electrodes
- Design: Portable with top carry handle
- Output Control: Adjustable
- Drive Roll: Quick-change for switching between flux-cored and stick welding
- Overload Protection: Thermal
- Case: All-metal
- Usage: General purpose stick welding, suitable for farm, auto repair, maintenance and fabrication applications.
Warranty
The Lincoln Electric Welder 11602 is accompanied by a warranty that lasts for 3 years. This warranty is comprehensive, covering any defects that may arise due to materials or workmanship. However, it's essential to note that wear items, including contact tips, nozzles, and drive rolls, are not covered under this warranty.
