4 Diagramas
Perguntas Populares do Fórum
Fazer uma perguntaNão há nenhuma pergunta. Seja o primeiro a fazer uma pergunta!
Modelos
113164 (F568)
Background and Identification
The Dri-Eaz Floor Fan model F568 is a high-volume floor fan that is designed to ventilate smoke, dust, and fumes and dry large spaces quickly. The fan includes an integrated stand that can be repositioned to direct air in a 260-degree range. Dri-Eaz advertises that the fan’s blade design delivers quieter operation and higher intensity airflow. The fan also features a variable speed control for airflow adjustments.
The Dri-Eaz Floor Fan model F568 includes a power outlet socket designed for daisy-chaining (connecting multiple power cords together) and can handle up to four units on one 15-Amp circuit. The fan uses 2.7 Amps of current and delivers 2600 cubic feet per minute or approximately 4417 cubic meters per hour of high-velocity air. The F568 model’s electric motor produces 0.45 horsepower or 340 Watts of power. The fan includes a 15-foot electrical cord, a circuit breaker, and a reset switch.
The Dri-Eaz Floor Fan model F568 can be identified by its blue plastic housing and black metal frame. It includes a black metal mesh that is positioned in front of the fan’s blades to prevent injury. The F568 model weighs approximately 27.5 pounds. The unit is designed to allow for stacking up to five total units on top of each other.
Technical Specifications
DISPLAY SKU: F568
UPC / ISBN: 666628918914
BRAND: Dri-Eaz
PRODUCT WEIGHT (LBS.): 27.50
POWER SOURCE: Electric - Corded
ADDITIONAL SPECIFICATIONS:
- Dimensions (D × W × H): 10.8" × 24.3" × 24"
- Air movement: 2,600 CFM
- Static pressure (H2O): 0.40”
- Amp draw: 2.7 amps, up to 4 per 15-amp circuit
- Sound level: 58–72 dB
- Volts: 115V
- Power: 0.45 HP/340 W
- Cord length: 15'
- Safety: ETL tested to UL and CSA standards
