Perguntas em alta no fórum
Fazer uma perguntaNão há nenhuma pergunta. Seja o primeiro a fazer uma pergunta!
Background
The Logitech B100 Optical USB Mouse is a simple, reliable, and affordable wired mouse designed for everyday office use. It offers plug-and-play convenience via a standard USB-A connection with no software required. An ambidextrous, full-size shape supports comfortable use for both left- and right-handed users. Optical tracking provides smooth, consistent cursor control suited to most work surfaces.
Identification
The B100 Optical USB Mouse can be identified by the model number ("M/N") M-U0026 (or part numbers, "P/N") 910-001439, 910-002839, 910-003357, 910-003360, 910-005227, 910-005547, 910-006066, 910-006605 depending on region, vendor, and color. The model and part numbers can be found Printed on a label on the underside of the mouse, near the optical sensor.. The device's serial number is also listed here, labeled "S/N."
Specifications
- Connection Type: Wired USB-A (Plug-and-Play)
- Sensor Technology: Optical tracking
- Resolution (DPI): 800 DPI
- Number of Buttons: 3 (Left, Right, Middle/Scroll)
- Scrolling: Line-by-line with scroll wheel
- Cable Length: 180 cm (5.9 ft)
- Handedness: Ambidextrous design
- Compatibility: Windows, macOS, Linux, ChromeOS
- Power: USB bus-powered
- Warranty: 3-year limited hardware warranty
Troubleshooting
If the cursor does not move or stutters, try a different USB port, clean the sensor window, and test on a non-reflective surface. Intermittent clicks or scroll issues often stem from dust or debris under the buttons or wheel—open the shell carefully to clean and inspect the wheel encoder and switch actuators. If problems persist, check the cable for kinks or breaks near the strain relief and consider replacing the USB cable or the primary microswitch.
For additional troubleshooting help, visit: For FAQs, downloads, and contact options, visit Logitech Support at https://support.logi.com.
Additional Information
Warranty Info
Limited hardware warranty (commonly 3 years for this model; terms may vary by region and require proof of purchase).
