Th screen stays black after a digitizer replacement.
I successfully replaced the digitizer of a customer's iPad Mini with the soldering method.
I connected everything and tested, and it was successful except for the home button. I disconnected the digitizer flex and the screen flex and the battery also. I wanted to test again and connected everything. I tried to turn on the Mini, but only had sound and no screen. The screen stays black.
iTunes recognises the Ipad Mini, and I did a DFU in hopes that it would work, but no success. NO SCREEN.
What can I do? iTunes says the battery is 100% charged.
Esta é uma boa pergunta?
15 comentários
Do you see picture just no backlight?
por Alfy
If I push the powerbutton, the Apple logo apears, but no backlite. Just seen this with the screen turned up into the sun.
por tuningdude
I need a clear picture of the fuse that must be jumped, or how to use the Bare Conductive Pen to create a jump across the fuse to "what?".
por Chester Henry
Replaced touch screen. Now have no picture. What fuse do in have to bypass. Can you post a picture or video. Thanks for the help
por Nick
i have the same problem ho can i fix it can u please help me
por glena
Exibir mais 10 comentários
