Retina fans mounted in normal MacBook Pro
Will retina Macbook Pro fans fit to older Macbooks (non retina) Pro. Is it possible to buy it somewhere?
Esta é uma boa pergunta?
Hey Sebastian,
Apple has been revamping their internal cooling systems a lot over the last few MacBook iterations. Because of this, the fans and connectors have been changing each time. Unfortunately, you cannot put a Retina fan inside of an older MB Pro.
Check out where the retina fan's connector is versus where the Unibody's connector is.
Hope this helps!
Guia
Nível de dificuldade:
Moderada
Guia
Moderada
20 minutes - 1 hour
Esta resposta foi útil?
Thanks for the reply. I guess the cable is not a problem for a skilled person. I wonder if it even fit into the fan's place... Must check it! ;-)
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 956
