Ir para o conteúdo principal
Repair guides, support, and troubleshooting information for MacBook Air models with 13-inch displays.
3527 Perguntas Visualizar todos
missing screw post on Logic Board
Hello .
I just purchased macbook air a1237 model.
Looks like it is missing screw post and screw located between cpu's .This screw is holding heat sink as well cpu bracket (v shape ) .
Is there way to buy missing post for the screw or fix that some how ? Looks like this mac is overheating now and turns off after few min .
See pic below on link
http://forums.appleinsider.com/t/151696/...
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
Try contacting iFixt directly if no one else pops up with the part.
''If this answer was helpful please remember to return an mark it Accepted..
Esta resposta foi útil?
Pontuação 1
2 comentários:
i did try this road already
por
Then purchasing a dead (for parts only) machine from e-bay is your only hope. You might be able to negotiate with a seller for only that part-if not get the offered machine and part out the remaining good parts.
por
If the heat sink is loose, and if a thin coat of thermal paste is missing those could be the causes of your overheating.
You could try contacting iFixit directly to see if they have the part.
Pontuação 0
Adicionar a sua resposta
Gregory Chojnacki será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 288
