Ir para o conteúdo principal
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
561 Perguntas Visualizar todos
Is the SSD replaceable in this model?
So I've seen another member ask this type of question, but it didn't quite answer my question. So if I have a 2.3ghz model, and it came with a 256gb SSD, will the parts from a 2.6ghz model that comes with a 512gb SSD work? LIke if I take out the 256gb SSD and replace it with a 512gb SSD from the 2.6ghz model. Just wondering if it works, if it doesn't, I think I'll have to wait for OWC..
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Solução escolhida
Yes they should - Apple will build it that way for you (the 2.6ghz is a custom build up of the 2.3ghz model). I don't think that it would be cost effective-but if you could luck into a damaged 2.6GHz model with a working 512GB Samsung flash memory module it will work. That's still the great thing about Apple - if it "fits" it generally works.
If this Answer is helpful please remember to return and mark it Accepted.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Thanks for the answer!
por
OWC
480GB Aura Pro 6G Solid State Drive
http://eshop.macsales.com/item/Other%20W...
Pontuação 0
Adicionar a sua resposta
04Stan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,158
