Não consigo tirar Selfie
Câmera para fotos de selfie fica escura. Câmera frontal.
Esta é uma boa pergunta?
@edsonboasorte best start is by verifying it isn't a simple software crash by clearing the camera app cache and booting the phone into Safe Mode. Go to Settings ==> Apps & notifications ==> See all apps ==> Camera. Tap Force Stop, then go to Storage & cache and tap Clear cache. Restart your phone and test the selfie camera.
If that did not work then try Safe Mode. Press and hold the power button, then tap and hold the "Power off" option on the screen until the "Reboot to safe mode" prompt appears. Tap OK. If the camera works in Safe Mode, a third-party app is blocking your camera. You will need to uninstall those recently downloaded apps until your camera works in normal mode.
If that did not work it is time to check the hardware. Open the pre-installed Device Help (or Moto Help) app. Navigate to Troubleshooting > Hardware test > Front Camera.
If your camera has failed you will need to disassemble your phone and replace the camera module. Since iFixit does not yet have a specific guide for this use something like this video. This video shows the rear camera but the steps are identical for your camera, just the different camera. Camera modules are readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person who has the same issues with their device. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
TRanslation
@edsonboasorte, o melhor é começares por verificar se não se trata apenas de uma falha de software, limpando a cache da aplicação da câmara e reiniciando o telemóvel no Modo de Segurança. Vai a Definições ==> Aplicações e notificações ==> Ver todas as aplicações ==> Câmara. Toca em «Forçar paragem», depois vai a «Armazenamento e cache» e toca em «Limpar cache». Reinicia o telemóvel e testa a câmara frontal.
Se isso não funcionar, tenta o Modo de Segurança. Mantém premido o botão de alimentação e, em seguida, mantém premida a opção «Desligar» no ecrã até aparecer a mensagem «Reiniciar no modo de segurança». Toca em OK. Se a câmara funcionar no Modo de Segurança, significa que uma aplicação de terceiros está a bloquear a tua câmara. Vais ter de desinstalar as aplicações que descarregaste recentemente até a tua câmara voltar a funcionar no modo normal.
Se isso não funcionar, está na hora de verificar o hardware. Abre a aplicação pré-instalada «Device Help» (ou «Moto Help»). Vai a «Resolução de problemas» > «Teste de hardware» > «Câmara frontal».
Se a tua câmara não estiver a funcionar, vais ter de desmontar o telemóvel e substituir o módulo da câmara. Como a iFixit ainda não tem um guia específico para isto, usa algo como este vídeo. Este vídeo mostra a câmara traseira, mas os passos são idênticos para a tua câmara, apenas a câmara é diferente. Os módulos de câmara estão facilmente disponíveis em muitas lojas online.
Enquanto trabalhas no teu telemóvel, tira muitas fotos. Quando terminares, usa essas fotos para criar um guia para a iFixit. Isso vai ajudar a próxima pessoa que tiver os mesmos problemas com o seu dispositivo. É fácil e divertido criar estes guias. https://pt.ifixit.com/Guide/new A comunidade da iFixit vai ficar grata por isso.
A reparação é uma guerra contra a entropia!
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Ao todo: 9
