Ir para o conteúdo principal
The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
224 Perguntas Visualizar todos
Screen is "locked up"
I have the original battery, it still takes a charge and phone was working properly. dropped. no obvious external damage. pushing the round recessed button lower center, or the black on button adjacent to the sim card produces the same result. black screen appears for < than 1 second.
Screen has an image of the planet earth upon which is superimposed a boxed msg "waiting for activation". slide to unlock does not respond, and screen goes black. sim card swapped for a known working card, with no change in symptoms.
What do you think the issue is? What parts do I need?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Pergunta mais útil
Can you connect to iTunes? If so, backup and restore the device.
If this doesn't fix the issue, try bringing the phone to a store of your phone service provider to see if they'll take care of it (DON'T MENTION THAT YOU DROPPED IT).
Good luck!
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
sam será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,053
