Ir para o conteúdo principal
Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
117 Perguntas Visualizar todos
Won't get past the loading screen
Alright I've recently been trying to fix my lap top since it broke a while back and I've decided that I want to fix it now since I want some files off of the laptop. The previous problem with it was that the screen would only be back. So I hooked it up to an external monitor and the screen seems to be fine now. However, the laptop wont load. It just stays at the apple screen. Anyway I can get this thing booted?
Esta é uma boa pergunta?
Pontuação -1
1 comentário
Also now it keeps turning off after being on the loading screen for about five minutes.
por
Adicionar um comentário
4 respostas
Solução escolhida
Hook it up to another Mac in Target Mode via a firewire cable hold the "T" key down on the iBook while booting. The hard drive icon should appear on the other Macs desktop. You can then recover files and run Disk Utilities. You can also try starting up from the system installation disk by inserting the disk and holding down the "C" key on boot up. If it comes up then run Disk Utilities.
Esta resposta foi útil?
Pontuação 2
2 comentários:
He says he doesn't have another mac.
por
thank you rab, he also said that after I made my post. Maybe he has a friend with a Mac.
por
It's odd that it shuts off after 5 minutes. If you twist around the AC adapter plug when it's connected and on, does it change colors and/or does the computer shut off?
If you have the reinstall media you can always do as Meyer suggests and boot off of it, and I would do a standard install, which will reinstall the OS with your files in place (if you don't choose the option to erase the disk). Hopefully your hard drive is intact and boot files have simply become corrupted, in which case this procedure should replace them and the machine should boot again.
If this doesn't work, rab77hp's procedure may be necessary. After recovering the files (assuming the drive is not bad), you can always put the drive back in and then reinstall the OS.
Pontuação 2
Do you want to boot it or just get your files off? If all you want is your files then you just need to extract the hard drive. Using this guide, remove the hard drive and place it in an enclosure and you can connect this to another computer and get your files off.
Pontuação 0
2 comentários:
I would like to boot it agian.
por
I don't have another mac.
por
It could be overheating, you might not have fully tightened the screws for the CPU heatsinks when you fixed it, this will cause overheating, and it might not have enough time to boot. You should open it up, and remove the screws for the heatsinks, and put them in, and tighten them evenly.
Pontuação 0
Adicionar a sua resposta
AlMoStLeGeNdArY será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 814
