Ir para o conteúdo principal
O Pontiac G6 foi um carro de porte médio produzido pela General Motors. Ele foi lançado em 2004 para o ano modelo 2005 para substituir o Grand Am.
Hardtop convertible won’t go up or down
  • Hardtop convertible won’t go up or down
Esta é uma boa pergunta?
Pontuação 0
1 comentário
@kevinronayne what is the exact year for your G6?
por Compartilhar
Adicionar um comentário
1 resposta
Pergunta mais útil
We need codes to better help you, but when it comes to convertibles it's complex to fix without codes. That said, a lot of the newer ones can be reset with a bidirectional scan tool and that will fix it if the computer that handles it is confused and locked it for safety. See if you can get a bidirectional scanner which can reset the convertible computers and try that first. However, sometimes it locks due to a failure like the hydraulic struts failing. The computer reset trick tends to be more commonly needed on anything German, but as a rule any convertible can lock and need a reset.
It's possible to disconnect the battery for 10-15 minutes on these, so a scanner may not be needed. If you pull the battery, re-index the windows by putting all 4 down, hold the switch for a few seconds and re-close them. That bypasses the computer reset, but you need to tell the system what down looks like.
Beyond resetting the computer, I would check the fuses, relays and hydraulic struts. The SM can be found here: https://cardiagn.com/pontiac-g6-2005-201... -- if the struts are fine, the motor that controls it will need to be replaced if you want the top to continue to work. GM has always been known for electrical quirks, especially on high motion parts - so that's another big area to check. It may also be due to a bad microswitch in the top. All of the parts that matter (panels, switches, struts) are NLA and will need to be purchased as NOS or used, so if you find it's something like a bad strut that's just going out, see if you can have the FTM computer reset to close it, and then pull the fuse and relay for the top.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Kevin Ronayne será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 16
Ao todo: 114
