Ir para o conteúdo principal
A1708/EMC 3164 — Lançado em junho de 2017, este MacBook Pro de entrada mantém as teclas de função tradicionais (em vez da Touch Bar OLED).
No power, fans spin at full speed
Imagem
Imagem
Imagem
Imagem
Imagem
Imagem
Imagem
Imagem
Imagem
Imagem
I got a 2017 13” MacBook Pro online for parts. The fans gradually ramp up and spin at full speed when plugged in. The trackpad connector was ripped off of the board and there is no ssd. Water damage indicators are also red, but no visual marks or stains. I get no image on the display, caps lock key does not light up when I press it. When unplugged, the system immediately shuts down. Any help?
Esta é uma boa pergunta?
Pontuação 1
26 comentários
@ryzobyte you got a lot going on there. First, take some good pictures of your logic board (both sides) and post those with your question, that way we can see what you see and hopefully can figure something out. This "The trackpad connector" will have to be replaced and let's see the damage from it being ripped off.
The reason why the fans gradually ramp up to 100% speed specifically when plugged into power, is because the System Management Controller (SMC) is reacting to an abnormal thermal reading, a missing sensor signal, or even heat generated by the charging circuit.
For this "When unplugged, the system immediately shuts down." sound like you may just have a bad battery.
Once your computer starts back up, run coconutBattery and post the pictures of the results with your question.
You can always start off by doing SMC Reset and running the Apple diagnostic. Let us know what you find out with all of this. That way we can focus on what to do first/next.
Adicionar imagens a uma pergunta já existente
por Compartilhar
@oldturkey03 Hi, I tried an SMC reset (no luck) and I can't access coconutBattery or Apple diagnostics since the unit doesn't power on. I will add some photos of the logic board tomorrow. Thanks
por Compartilhar
@ryzobyte yes, of course. I did mean to check the battery once your computer boots back up :-) I've made the edit to my original comment :)
por Compartilhar
@oldturkey03 I added a quick picture of the board where the connector was ripped. I will take some better pictures of the logic board tomorrow.
por Compartilhar
@oldturkey03 uploaded images of both sides of the logic board. The trackpad connector is ripped off of the board
por Compartilhar
Exibir mais 21 comentários
Adicionar um comentário
1 resposta
Pergunta mais útil
Based on your description, the MacBook is showing signs of a hardware-level failure rather than a simple missing SSD. The fans ramping up to full speed, no display output, Caps Lock not responding, and the system shutting off immediately when the charger is disconnected all suggest that the logic board is not completing the boot process. The ripped-off trackpad connector is also significant because, on this model, the battery connects through the trackpad assembly, so damage there can prevent battery operation and explain why the MacBook powers off as soon as it's unplugged. The red liquid contact indicators further increase the likelihood of corrosion or component damage, even if there are no obvious stains. I would first inspect and repair the damaged trackpad connector, verify that the battery is properly connected, and then test the board with a known-good SSD. If those checks don't restore functionality, the logic board will likely need board-level diagnostics to identify any liquid-damaged or failed components.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Ryzobyte será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 38
Ao todo: 303
