Hi Jeremiah,
Your phone is similar to many Android phones in that there are two ways to replace a screen. If you buy a factory replacement from Motorola, it will come already mounted on the midframe. That's their recommended method of screen replacement; you basically gut the phone and move all of the internal components over to the new screen+frame assembly. This video steps you through the process.
Motorola Moto G 5G 2025 screen replacement ,xt2513 - YouTube
The other way to replace the screen is to remove only enough components to access the display's flex cable and unplug it, then you have to separate the old screen from the midframe. Clean off all the old adhesive from the frame, then lay down a line of glue all around the outside edge and glue the replacement screen onto the frame. Most people then secure the screen until the glue is dry, either by weighing it down, clamping it, or wrapping it in rubber bands. Once it's dry, then you can proceed to reassemble the parts you removed previously and you're done.
Unfortunately, I wasn't able to locate a video showing that particular repair, but the essence is you would follow the video I gave you first to remove the rear panel and retaining frame, then disconnect and remove the battery. Unplug and peel up the display connector, then use heat and/or alcohol to separate the display from the midframe. Clean and glue, then reassemble as I mentioned earlier.
You should be aware that a significant part (maybe even most) of iFixit's content is made by users like you and me, and you're just as capable of making a guide to this repair as anyone else. All you have to do is take lots of pictures as you work, then once you're done you can use them to create your own iFixit guide to the Motorola Moto G Stylus 5G (2025) Screen Replacement. It's easy, fun, and will be appreciated by the repair community, especially people with the same problem.
Create a new Guide - iFixit
Good luck, and be sure to let us know how it all turns out!
