Ir para o conteúdo principal
Informações sobre reparo, desmontagem e resolução de problemas do smartphone Android Xiaomi Redmi A5, incluindo os modelos 25028RN03A, 25028RN03L e 25028RN03Y. Ele possui uma tela de 6,88 polegadas, processador UNISOC T7250, câmera traseira de 32 MP e bateria de 5200 mAh.
Why is the phone not charging?
phone switched off after all power was drained now its not charging why ?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
@antonioand26660 first check your charger. Make sure it has proper output. Then check your charging cable. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a USB ammeter and see if your phone draws any amperage from the charger. If it does not it is possible that this is a charging port issue or a bad battery.
To check the charging port, use a voltmeter and measure the voltage on your battery connector. Next plug your phone charger in. Now measure the voltage on your battery connector. That voltage will have to have increased. IF not then the issue is either the port or the charging circuit.
Most likely parts to change are the charging board and the battery. Do not forget to check the flex cable from the charging board to the main board. Sometimes those get corroded or end up with micro tears.
Since iFixit does not yet have a specific guide for this, use something like this video
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same issues with their device. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Esta resposta foi útil?
Pontuação 1
Why phone not charging
Pontuação 0
1 comentário:
@rakshithab92639, did you read the answer provided by @oldturkey03?
Did you go through the troubleshooting steps he suggested? If so, what did you find? If not, try reading the information already given rather than just asking the same question again.
por
Adicionar a sua resposta
Antonio Andy Lekuni será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 53
Ao todo: 136
