Ir para o conteúdo principal
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
553 Perguntas Visualizar todos
Bottom cover not flush - clicks/pops
Guys I just picked up the macbook pro retina 15"
The bottom cover on the left side under the thunderbolt port isnt seated flush and pops in and out faintly.
Is this a simple issue where it wasn't lined up properly and screwed in? Or is it something more serious?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Sounds like something is bent or jammed under the lip of the case so it won't seat correctly. I would return the unit to the store you bought it from ASAP to get it exchanged out. You don't want to be stuck with a lemon!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
slim será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,253
