Ir para o conteúdo principal
Bajaj Auto Limited is a premier Indian multinational automotive manufacturer and the world’s third-largest producer of motorcycles and largest producer of three-wheelers. They manufacture motorcycles, scooters and auto rickshaws. Their portfolio includes the iconic Pulsar and Dominar performance motorcycles to the Chetak electric scooter and the RE three-wheeler.
Cd 100 bajaj There speed metter is not working
There horn ,speed meter is not working
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@sherbaazdh82703 your horn and your speedometer are not connected. Your speedometer uses a cable that connects to the front wheel and the other side to the speedometer. You will most likely have to replace that to repair your speedometer.
As for your horn, connect a jumper cable from the battey to the horn and see if it works like that. If so, it is not your horn that has failed but possibly the switch or a bad fuse.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Sherbaaz Dhaliwal será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 19
Ao todo: 55
