Ir para o conteúdo principal
Second generation of the Ford Focus.
95 Perguntas Visualizar todos
How do you change the fuel filter in a 2007 Ford Focus?
Esta é uma boa pergunta?
Pontuação 2
2 comentários
were is the fuel filter on usa ford focus 2007. how do I best change this filter
por
hi there
i have a 2007 ford focus 1.6 si hatch back and my fuel filter is attached on the the frame of'
of the back axle. i have seen pics of other cars location and i cant understand why my car is different.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
James, there are great write ups with images on here and another very good one right here. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 2
3 comentários:
Hi Thank you but my ford is a european focus which seems to have a different filter, do you know of anywhere for these?
Kind Regards
por
James, here is one for the UK model "it is in a recessed area just ahead of the fuel tank - visible on the passenger side just ahead of the rear wheel. You have to release the fuel pressure with a special hose clamp release tool before removing the hoses. Then there's one small clamp bolt that holds the filter itself.
por
i am confused now because my fuel filter is attached to the back axle frame and it
does not look like the one in the pics.
por
Adicionar a sua resposta
James será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 10,399
