Harddisk Temperature Sensor broken
Hello,
i broke the temperature sensor of the harddisk, while replacing it. the small board with the smd sensor broke in two peaces.
So where can i get a replacement? Or i can i simply solder a normal temperature dependent resistor?
I looked around, but found only cable for older mac mini models, an i am not sure, if they also fit in the A1347.
Kind regards
Jens
Esta é uma boa pergunta?
1 comentário
The last three figures of the serial number are D6H.
por Jens Wagner
