Ir para o conteúdo principal
O Lenovo IdeaPad S540-14IWL é um notebook projetado para uso geral, com uma tela de 14 polegadas e um perfil fino.
Ram compatibility to upgrade ram
  1. Dose this model support 16 GB DDR4 2666Mhz ram
  2. Is it's motherboard capable for support 20 GB ram total
  3. As we it has 4 GB solded ram so my question is can I put 16 GB card in ram slot will support.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
It might be limited to 12-20GB, which is typical for the partially soldered PCs :-(. A lot of them stop at 12GB, but there's been a few that have begun taking the full 20GB -- you'll need to check the specs and give it a try to see if it can do 20GB of RAM.
This is officially a 12GB machine though: https://psref.lenovo.com/syspool/Sys/PDF... -- you'll know if it works if it doesn't POST, throws weird errors or stops at 12GB with 20GB installed.
Esta resposta foi útil?
Pontuação 2
Yes, in many laptops with 4GB soldered RAM + 1 slot, you can install a 16GB DDR4 2666MHz stick, making total 20GB RAM (4+16)—if the motherboard supports it.
Some models officially list lower limits (like 12GB), but practically support 20GB.
Key points:
Match RAM type: DDR4 SODIMM, same or supported speed
System will run part in dual-channel, rest in single-channel
Always check your exact laptop model specs before buying
If your model supports it, yes—16GB + 4GB = 20GB will work.
Pontuação 0
Adicionar a sua resposta
Koshtick Chakraborty será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 40
Ao todo: 193
