Randomly sleeping and shutting down with battery plugged in.
Hi guys,
I just baught this MacBook and it randomly keeps going to sleep and shutting down. A couple Mac fix people in town said it was the logic board most likely however I removed the battery and it works 100% without the battery in. I'm going to replace the battery connector and the battery sensor cable. The sleep sensor seems to be fine and it seems unlikely that it would be the sleep sensor as the machine only malfunctions with the battery attached. I don't have another battery to test it but I don't think it's the battery. Any ideas? I've already reset the power management and pram as well as the os has been reinstalled.
Esta é uma boa pergunta?
Have you tried ASD (Apple Service Diagnostic) test?
ASD
por Jech
Yes. ran a add OS and EFI test today. The only failure was and internal display error 72 when running the 2D accelerator. I don't think it has anything to do with the battery issue. Oddly enough when in the OS ASD it boots into a version of snow leopard and the unit did not sleep at all as it does when in the true os? Im wondering if there may have been a spill thats causing the random sleep issues as there was another post with the same issue and he just had to clean his logic board? I really don't want to pull the board but i might have to. Does anyone know what causes the macbook to go to sleep. I know there is a sleep IR sensor cable by the HD but i think it is only the indicator? would that cable have the ability to trigger sleep mode?? The battery issue leads me to believe it is a faulty ground although all tests on the battery past? maybe i will try running the ASD again with the battery pulled and see if i have the same failure?
por Peter Fiorino
