Fitting Two 750gb hybrid drives
Can I fit two 750Gb hybrid drives in my mac book pro 2010 and if so what extras will I need and can the standard fan cope with the additional heat?
Esta é uma boa pergunta?
Favor a 7200 rpm HDD for system and 5400 for additional HDD.
You don't need to modify fans or other stuff in your MacBook pro.
Esta resposta foi útil?
When you say "hybrid" you mean "Momentus XT Hybrid"?
I have to tell you, the "hybrid" part is not supported by Apple and OS X.
That means your hdd will work normally as standard hdd.
I understand!! So in that case if I use 2 500Gb SSD drives instead, what are recommended drives and what other extras will I need to complete installation? Will the standard fans cope? Any other problems
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 314
1 comentário
I understand!! So in that case if I use 2 500Gb SSD drives instead, what are recommended drives and what other extras will I need to complete installation? Will the standard fans cope? Any other problems?
por David Lamport
