Saw is smoking and lost power
How to test field wires with ohm meter
Esta é uma boa pergunta?
@glenngrodski unplugging the saw is essential :)
Set the multimeter to the lowest (ohms) setting, or use continuity mode (buzzer) (depends on what your meter has). Connect one probe to one end of the wire and the other probe to the opposite end. If your meter shows a low resistance reading it indicates a good (closed) circuit, while "OL" or "1" means a break (open) in the circuit.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Ao todo: 97
